Results 1 to 20 of 21
    Newport, Mi.
    1999 Camaro SS
    Need help pulling motor - broke motor at a road course event
    I broke something in the bottom of the motor,,, when I pulled the dip stick to check for coolant in the oil, the stick come out very hard,, the last 4 to 5" is curled up 180 degrees and the last 1/4" is bent over. I am going to have to check the bottom end to determine what is wrong, I think.
    I have a '99 with the 6-speed, should I pull the tranny with the motor.
    Any tips?
    '99 Camaro SS; 6-spd, LS2 402 stroker short block, PP stage 3 heads, GMS MAF, 244/248 cam, FLP headers, Borla catback, 4.10 gears, LS6 intake, 39#/hr injectors, Pro 5.0 shifter, subframe connectors, Comp Cams 1.85 rr,
    Best ET: 12.23sec (2.000sec 60'), trap spd:117.5mph, with the LS1 engine.
    Marylandistan
    2001 Trans Am (sold)
    Jeez that sucks man. I wouldn't know where to begin. Does it start/run? Have oil pressure?
    Newport, Mi.
    1999 Camaro SS
    I coasted off the track and stopped, the engine had alreay quit,,, I sat there for about a minute then decided to turn the key. A couple cylinders fired but the engine seemed way out of balance, so i quickly turn the key back off.
    With my '87 Camaro, I pull the auto tranny with the motor. Has anyone done this with a 6-speed on an LS1 car?
    Member ultra_badass's Avatar
    Corpus Christi
    navy blue matallic
    2000 WS6 trans am M6
    if you can get it high enough the only way i have ever seen it done is out of the bottom
    Member camaross19973's Avatar
    Los Angeles
    blue
    1999 camaro ss #976
    that is the only way and the correct way to do it. at autozone they have this book call how to build high-performance chevy ls1/ls6 V-8s it cost about 20 bucks or so. but it will tell u how to do it right. good luck on fixing it
    Newport, Mi.
    1999 Camaro SS
    I do not have a car lift at home in order to pull the motor from out the bottom.
    Has anyone ever pulled the motor out the top? Can this be done?
    Corpus Christi
    navy blue matallic
    i have heard about it being done from the top with the tranny an all but how i dont know.... but i do know as far as time it gives 15.4 hours to pull and relpace it from the bottom that is...good luck man
    Marylandistan
    I've seen people use an engine hoist to lift the front of the car off the k member in their garage/driveway.
    Newport, Mi.
    1999 Camaro SS
    That was a good suggestion to use the engine hoist to lift the front of the car in order to drop the motor out the bottom.
    It seems that I will pull the motor & tranny as a unit out the top. But I am still invetisating doing it from the bottom.
    Member jbb6811's Avatar
    south carolina
    blue,blue
    00 z-28 m6, 06 H3
    i would find some one with a lift to help you. out the bottom is the way to go!
    i would think you'd have to take the nose and radiator ect out to come out the top. out the bottom the k member front susp. motor and trans can come as one piece. good luck
    Aug 2000
    Indy
    Disconnect the tranny. It will come out the top.
    Marylandistan
    I've read people say it's a nightmare going out the top. Good luck.
    Newport, Mi.
    1999 Camaro SS
    Thumbs up
    I recently checked the QTP site,,, they have an engine lift plate, and a video showing an engine being pull out of the top with the hood still attached.
    Junior Member TwiSSter418's Avatar
    Florida mostly
    I took my motor out through the bottom and it was soooo easy. There are like 6 bolts holding the k-member on. I took the front wheels off and sat the k-member and motor on rollers then just disconnected all the wires (the hardest part actually!) and the trans crossmember. I used a cheap floor jack to keep the trans supported. After everything's unplugged, i just strapped a chain around the "frame" rails behind the radiator and lifted the front end up using a normal engine hoist. Theres no weight on the front end anymore, so don't worry too much about breaking anything. The whole assembly slid out under the driver side wheelwell because i couldn't get the front high enough. but the whole ordeal took only a few hours and really wasn't as bad as i thought it was going to be. There are a few tutorials online somewhere, I just used those as a guide! good luck!
    Junior Member Twistingreality's Avatar
    Oklahoma
    2001 Camaro
    Quote Originally Posted by camaross19973 View Post
    Get this book very detailed info with pics on how to take it out.
    Newport, Mi.
    1999 Camaro SS
    I will buy this book in the next two days. My QTP engine lift plate will be here tomorrow!!!!!
    I found part of my engine problem. I removed the starter, and the side of the block in smashed outward from the inside, just above the starter motor. I have about a 1 1/2" hole in the block. I am sure the rotating assembly is history too.
    So now its time to investigate LS2 derived short blocks that are compatible with LS1 F-bodies.
    Corpus Christi
    navy blue matallic
    same thing happend to me exact same spot and pretty much the same diamater ill post pics tomorrow
    Newport, Mi.
    1999 Camaro SS
    Yea, I'm also assuming that the rotating assembly is toast,,, what else would have knock that hole in the side of the block.
    This is going to be very expensive fix. In stead of finding a used LS1, I feel like dropping some big coin on a very big short block from Texas Speed.
    Corpus Christi
    navy blue matallic
    here ya go
    Driver for hire ss_caramo's Avatar
    N. Texas
    2001 SS (M6) #4581
    Quote Originally Posted by Doc99SS View Post
    There probly isnt much "Fix" involved with your catastrophe. You are on the right track by thinking of starting over fresh. With that kind of engine failure, there usually isnt much that is salvagable inside. Its possible that it got all the way up into the valvetrain and did damage there as well. Good luck on your repair / replace project.
  1. pulling ls motor
    By muscatine73 in forum General Help
    Last Post: 01-01-2009, 08:57 PM
  2. Pulling the motor again
    By badazta in forum General Help
    Last Post: 06-14-2008, 03:52 PM
  3. Pulling out my motor Help!!!
    By JD_Z28 in forum General Help
    Last Post: 03-04-2006, 04:38 PM
  4. YUP, pulling the motor AGAIN!!!
    By HASTINGSRJ in forum Western Members
    Last Post: 10-27-2005, 06:19 PM
  5. YUP, pulling the motor.......
    Last Post: 08-21-2005, 08:00 AM
