Thread: Vibration
02-08-2008, 07:53 AM #1
Vibration
I got a 2000 Camaro SS and it has a bad vibration even while idling. It is pretty bad going down the road also, but i can't figure out why its vibrating in park? The higher you rev the RPM's up, in park, the worse it does it. Can you think of anything that it could be?
02-08-2008, 08:00 AM #2
02-08-2008, 08:06 AM #3
is it a vibration or a miss? like spaz said, very easily could be the motor mount. If you check the mounts and they're fine I'd look at maybe the flywheel next.
02-08-2008, 08:14 AM #4
02-08-2008, 09:15 AM #5Alabama Member
- Jan 2008
- heart of dixie
06 Jeep Grand Cherokee.- 02 superchipsZ28 M6(sold)
all of the above and look for loose pulleys
02-08-2008, 12:04 PM #6
All of the above and check your exhaust that is not making contact with any parts. I had a bad tranny mount and my vibration was on the dash running around 90-110 mph. I end up getting the OEM mount. I tried the polyurethane one and it was worse because is a harder material. Put the OEM in and problem solved.
vibration
By jsmith564` in forum General HelpReplies: 213Last Post: 02-25-2012, 05:50 PM -
vibration
By ron83 in forum DrivetrainReplies: 16Last Post: 03-29-2011, 05:01 AM -
Help: Bad Vibration
By 2001TransAm in forum DrivetrainReplies: 12Last Post: 11-24-2009, 07:42 AM -
vibration
By shadowsnkx in forum DrivetrainReplies: 4Last Post: 07-31-2008, 07:14 PM -
vibration
By JROBINSON1016 in forum Internal EngineReplies: 5Last Post: 03-20-2007, 06:23 PM
