Results 1 to 17 of 17
Thread: vibration
03-24-2011, 07:37 PM #1
vibration
Getting vibration at Hwy speeds in center console area any suggestions
03-24-2011, 09:00 PM #2
check a few things.
1. check your tranny mount. If it is broke it will cause vibrations.
2. U joints in your driveshaft. lift the car that you can get underneath and grab the driveshaft twist it side to side and look/feel if you have any kinda of play on the U joints.
03-24-2011, 09:17 PM #3
i think most of the time these things tend to be out of balance wheels...
or as jata98 says, it could be u-joints or an out of balance drive shaft...
if it's annoying you, i'd try getting the wheels balanced first, ...see if that solves it.
03-25-2011, 04:12 AM #4
03-25-2011, 06:06 AM #5
No steering wheel vibration all new mounts and I sent the drive shaft out twice but it still has balancer on the ffront of it also I balanced my wheels yesterday
03-25-2011, 06:23 AM #6
03-25-2011, 07:39 AM #7
Yep and im running out of options
03-25-2011, 08:07 AM #8
maybe your pinion angle? have you messed with gears?
03-25-2011, 08:26 AM #9
Yes 3.73 gears they have been in their for a while and I just checked the pinion angleirs good
03-25-2011, 08:44 AM #10
Sorry the angle is good
03-25-2011, 08:47 AM #11
hmmm thats odd. everything balanced and angle is good doesnt make since
03-25-2011, 06:29 PM #12
Yeah once I get I figured out I will let y'all know
03-26-2011, 03:39 PM #13
Sounds good. Good luck
03-27-2011, 05:46 PM #14
03-27-2011, 07:31 PM #15
Energy suspension motor and tranny
03-28-2011, 05:35 PM #16Senior Member
- Apr 2008
- Madison, WI
ah ok. Well there have been some problems with the poly trans mounts being too tall and they are throwing off the d/shaft angles...causing vibrations.
Check out this thread:
mods for poly trans mount to eliminate driveshaft vibration
03-29-2011, 04:01 AM #17
that could be the problem like Cutlass said. I had ES tranny mount and I installed per the instructions in the box. My center console and dash was vibrating like hell. I bought the stock mount and no vibration. If you don't do the ES tranny mod, the mount sits higher and changes the DS angle. The only other way to fix it is if you have an adjustable torque arm.
vibration
By jsmith564` in forum General HelpReplies: 213Last Post: 02-25-2012, 04:50 PM -
vibration
By jcdonjuan04 in forum Automatic TransmissionReplies: 8Last Post: 11-26-2009, 07:09 PM -
Help: Bad Vibration
By 2001TransAm in forum DrivetrainReplies: 12Last Post: 11-24-2009, 06:42 AM -
vibration
By shadowsnkx in forum DrivetrainReplies: 4Last Post: 07-31-2008, 06:14 PM -
vibration
By JROBINSON1016 in forum Internal EngineReplies: 5Last Post: 03-20-2007, 05:23 PM
