Page 1 of 3 123 LastLast
Results 1 to 20 of 44
Thread: Trunk Lift
    Junior Member pafuller's Avatar
    Jan 2008
    Hershey, PA
    2000 Z-28
    Trunk Lift
    Does anyone know how to change out the trunk lifts on a 2000 Z28 ?
    Senior Member bills98ta's Avatar
    Feb 2007
    St Thomas, PA
    Are you talking about the two lift cylinders ? If so, there's a metal snap clip that needs removed on each end...Small straight screw driver...
    Jan 2008
    Hershey, PA
    2000 Z-28
    Thumbs up
    Thanks the spring clip I found out is the easy part. The other end is a T-50. I started the project today to discover that the lifts that I bought won't work. So I'll have to wait on this project.
    Thanks for the reply!
    Feb 2007
    St Thomas, PA
    Good Luck !
    Member chevyss1234's Avatar
    Feb 2007
    Clemson SC
    i'm just curious what exactly ya'll are talkin about i'm confused
    Jan 2008
    Hershey, PA
    2000 Z-28
    Replacing the gas (shock like) cylinders that keep the trunk lid open. It doesn't pop open anymore to I wanted to replace them.
    Single Malt rbob93's Avatar
    Ft. Lauderdale, FL
    Sebring Silver
    2000 CamaroSS
    The gas shocks have nothing to do with the lid popping open, they just keep the lid from closing while opened.
    The spring that pops it open may need a helper spring added. Simple 5 minute fix.
    Jan 2008
    Hershey, PA
    2000 Z-28
    The lid unlatches and opens, the lift's then help the lid open all the way. My lid opens OK it just doesn't open all the way. Hey it's a 2000 with 70K on it I can't complain.
    SATX
    2000 Trans Am
    okay i think i have problems with this two, mine gets stuck once i hit the button. i usually have to be ther so i can open it as i push the button, would you please include a pick on where the springs are located? thank you.
    Jan 2008
    Hershey, PA
    2000 Z-28
    I received the wrong lift's, I think here is a picture, the one on top is the original one the other two are what I received.
    Jan 2008
    Hershey, PA
    2000 Z-28
    Doe's this help ?
    SATX
    2000 Trans Am
    those are the shocks right? is there any springs that go around the latch?
    Jan 2008
    Hershey, PA
    2000 Z-28
    I am not familiar with any springs, with the problem that I am having. Someone earlier mentioned springs on the latch.
    Houston, Texas
    2000 C5 Torch Red
    Yeah, what he was talking about earlier was the release latch spring is rather weak. After a while when you pop the trunk it may take two tries or so to be able to lift the trunk.
    The shocks do nothing for the initial release of the trunk, its a spring (open the trunk and pull back the center liner where the hood latches). You'll see a spring.
    You can buy a replacement at home depot or lowes that's compact enough to pop the trunk free again. If your trunk opens and holds fine once lifted, I would replace that spring first. I believe you can search the site and find a write up.
    Houston, Texas
    2000 C5 Torch Red
    Member CJREX's Avatar
    GA
    Gone:2001 Camaro SS #4846
    Just replacing the spring won't necessarily fix it.
    I put the helper spring on mine just like the above write-up described and my hatch still wouldn't pop open.
    Had to replace the hatch struts and now all is OK.
    My hatch would stay open at the top but would not hold up in any other position.
    It would always sink back down. My struts were just too weak.
    10 minute (and $50) fix.
    SATX
    2000 Trans Am
    thank you that was the problem with mine. my shocks are okay, every week i kept spraying wd40 on the latch thinking it was going to fix the problem, but man was i off.
    Senior Member OnEbAdReDSS's Avatar
    Puyallup
    2000 Camaro SS # 5,876
    my shocks sqeek when i drive... what should i do... still hold the hatch up
    SATX
    2000 Trans Am
    grease the fittings and then tigthed them. they might be loose
    Puyallup
    sweet thanks
  1. max lift
    By Truspeed in forum Internal Engine
    Last Post: 11-22-2010, 01:04 PM
  2. I have a .630 lift...?
    By MurderedOutTA in forum Internal Engine
    Last Post: 10-20-2010, 03:56 PM
  3. Question: Max Lift for CAM
    By pmolina0436 in forum GTO
    Last Post: 01-08-2009, 08:34 PM
  4. Looking for a Used LS1 Cam 590 or less lift
    By Regal Performance in forum Firebird / WS6
    Last Post: 11-01-2006, 06:44 AM
  5. Best cam for .600 max lift?
    By phoenix1987 in forum Internal Engine
    Last Post: 10-01-2006, 09:41 AM
