Results 1 to 16 of 16
Thread: I have a .630 lift...?
10-05-2010, 07:23 PM #1
- Nov 2009
- Wichita Falls Tx
Black- 1998 Trans AM
I have a .630 lift cam for my 98 TA. my question is does anyone kno if the valves will hit the stock pistons, has anyone experienced this or does anyone kno if it will work or not? any help would be great!
10-05-2010, 10:52 PM #2
- Thornton, CO
Not anywhere near enough information to give an answer.
Best bet....MEASURE!
10-06-2010, 02:27 AM #3
10-06-2010, 08:10 PM #4
- Nov 2009
- Wichita Falls Tx
okay well then i guess my question is what is the biggest cam u can run with the stock pistons?
10-06-2010, 08:31 PM #5
10-08-2010, 04:49 PM #6
10-08-2010, 07:44 PM #7
10-08-2010, 08:45 PM #8
- Dec 2007
- SAN FRAN SISCO BABY
VW BEETLE W/ FLOWER- 88 CRX
holy mother of god! 630 lift?! how big is your motor?
10-08-2010, 09:25 PM #9
10-10-2010, 03:10 PM #10
10-19-2010, 01:41 PM #11
- Oct 2007
- NC
SOM- 1998 T.A.
Duration has much more to do with PTV than lift since max lift occurs near BDC. The biggest you can fit w/o flycutting is somethin like a Trex, Polluter, MS4 etc.... Those cams suck though if you don't have a high stall (A4) and gear......
Even those cams you need to measure PTV and are under the recommended .080 intake and .100 exhaust minimums...
OP what is the duration, LSA and advance (or installed ICL) on your cam.....Last edited by SOMbitch; 10-19-2010 at 01:44 PM.
10-19-2010, 02:07 PM #12
- Jun 2009
- Saint Louis, MO
Arctic White & Black- '98 WS6 M6 - SWAPTIME!
I have a '98 w/ a .621 lift cam, daily driver ... I have 243 heads with the lighter stock valves with stock pistons ... no problems. but as Luos said ... MEASURE before buying a set of valves and pistons is the least of your worries
10-20-2010, 03:23 PM #13
- Sep 2010
- Ohio
midnight blue- 1998 Pontiac trans am
Don't the stock rockers go into bind or lock after .625 lift. I thought I saw that somewhere.
10-20-2010, 03:39 PM #14
10-20-2010, 03:54 PM #15
- Sep 2010
- Ohio
Ok. I wasn't stateing a fact it was more of a question.
10-20-2010, 03:56 PM #16
- Sep 2010
- Ohio
So how much lift can you run on stock rockers. I know there is a limit because of the way they are designed. They will only rotate so far and then they hit the flat.
Max Jax Lift
By MrKid in forum ToolsReplies: 44Last Post: 11-06-2016, 04:34 AM -
Question: Max Lift for CAM
By pmolina0436 in forum GTOReplies: 22Last Post: 01-08-2009, 08:34 PM -
how much lift is ok?
By TmaxicanA in forum Internal EngineReplies: 13Last Post: 03-06-2008, 11:06 AM -
Looking for a Used LS1 Cam 590 or less lift
By Regal Performance in forum Firebird / WS6Replies: 1Last Post: 11-01-2006, 06:44 AM -
Best cam for .600 max lift?
By phoenix1987 in forum Internal EngineReplies: 8Last Post: 10-01-2006, 09:41 AM
