Thread: AWD Astro van help...?
01-28-2008, 08:30 AM #1Member
- Jan 2008
- Lowell MI
metallic burgandy- '00Pont Grand PrixGT
Board here has been a BIG help in the past for me. Hope it can help my brother out too. He has a 2000 AWD Astro VAn. When parking or turning tight, growls, grunts, groans, and feels like it is binding all up. Similar to a 4WD with posi front end and lock outs still engaged on dry pavement. Wondering how the system works, what to look for, or where to go for tech advice/help. THANKS in advance
01-28-2008, 04:01 PM #2
There is a clutch in the transfer case that is sticking. It's a common problem. Change the t case fluid with GM Auto Trac 2 and drive it 100 miles and then change the fluid again. This should cure your problem.
You will need 4 quarts total.
01-29-2008, 01:38 AM #3Member
- Jan 2008
- Lowell MI
THANKS much. I have already passed it on. Sounds a bit like a limited slip axle situation. Clutch pack binding and sticking w/o proper additives. MUCH Appreciate the help!!!!!
01-29-2008, 01:40 AM #4Member
- Jan 2008
- Lowell MI
You guys have got the greatest smilies here. LOVE the burnout!!
Help: 1997 Chevy Astro LQ4 Swap, Low Power
By chevyastroawd in forum General HelpReplies: 25Last Post: 03-12-2016, 01:23 AM -
Anyone know anything about Chevrolet Astro vans?
By compuvision02 in forum Almost Anything GoesReplies: 45Last Post: 10-21-2007, 09:04 PM -
ASTRO CARGO VAN vs JETTA!!!
By Rikki_SeVeN in forum Kill StoriesReplies: 19Last Post: 09-14-2007, 04:44 PM -
Astro Shield Polish
By Smkn_TA in forum Showcar and DetailingReplies: 1Last Post: 09-01-2007, 11:59 AM
