    Member 28Marcos's Avatar
    SATX
    99 Z/28
    Angry i'm tired of this please help
    My alarm is going crazy and its very embarassing. I was trapped again at my nephews elementary school for 15 minutes with my alarm going off nonstop. This happened before and I thought I fixed it but I guess not.
    When I hit unlock on the remote the siren chirps 4 times then an alarm cycle is triggered and the starter is locked out. Normally to override this, i turn the key to on, then hold the override button then it turns off. But today it would not listen to me, nor anything i did. Now whenever I hit unlock on the remote, the alarm cycle goes off.
    DO you know whats going on? what do I do?
    SATX
    99 Z/28
    went to my car, hit unlock on the remote, alarm went off, then hit unlock 2 more times and it went off ??? wtf? turned down my shock sensor, hoping that it jiggled itself too senistive...
    Feb 2006
    Orange County, NY
    always dirty
    2013 Ram 2014 Caddy ATS
    what override button are you talking about?
    Senior Member
    Jacksonville, FL
    Sounds like you have an aftermarket alarm.
    SATX
    99 Z/28
    i thought it was the override button lol, its the one under the dash, is that teh valet button? i was told that on some gm cars, when the alarm goes off, put the key in the door turn it left then right or vise versa , or turn the key to on, disconnect the battery, then connect it again, that should reset the alarm...what do you think
    Dawson, IL
    2000 Trans Am
    Check the shock sensor - there is a little black box above the passenger rear wheel, pull off the cover above the spare tire and above the wheel well back there you should find the little box. Disconnect the cable and see if that solves your problem, common for them to go out....
    SATX
    99 Z/28
    it turns out my alarm IS aftermarket! all these years i thought it was factory lol what a dumb@$$
    So how would i go about disconnecting this aftermarket alarm cause it goes off everytime i hit unlock on the remote, like it is disagreeing with the keyless entry
    FLA
    you can try to place the alarm in sleep mode ( Valet mode ) if you have another remote or just try pulling the fuse for it and see what happens , a lot of things depends on the way it is wired in and the type of alarm system there is
    SATX
    99 Z/28
    well, I dropped the panel under the steering wheel, found a mile of wires, followed the red and black wire from the siren under the hood, and now i just about know what every wire does lol, and as of now my problem is solved, and I got a ghetto killswitch out of it haha i'll leave it like that until I can afford a new alarm next month
  1. I'm Tired
    By c5z28 in forum Political / Debate Forum
    Last Post: 03-30-2010, 07:56 PM
  2. Tired LS1
    By wolvealone in forum Internal Engine
    Last Post: 10-09-2007, 12:08 AM
  3. who else is tired of seeing
    By jrc1122 in forum Domestics and Foreigns
    Last Post: 07-27-2007, 07:10 AM
  4. I'm so tired of being ...
    By Sarge in forum Almost Anything Goes
    Last Post: 02-22-2007, 07:56 PM
  5. tired Ls1
    By z28gc222 in forum Camaro / SS
    Last Post: 02-09-2007, 09:32 AM
