Results 1 to 10 of 10
Thread: LS1 Fuel system
    Jan 2008
    Tucson, AZ
    Puter
    2002 Z28
    LS1 Fuel system
    Anyone have a link or information to an accurate description of the 2002 Z28 fuel system?
    Al
    Bragg NC
    Met. Sunset Orange
    01 SS
    What exactly are you looking for? Info wise.
    J
    Jan 2008
    Tucson, AZ
    Puter
    2002 Z28
    Quote Originally Posted by sunsetorangess View Post
    J
    The complete system operation, from the tank to the injectors.
    Al
    I'm still a little unclear on exactly what you're looking for but I'll tell you what I know.
    The pcm feeds the fuel pump relay which feeds the pump (there's also a fuel pump fuse). The pump is just like most late model GM's as it's a "module" and has the pump, level sender, and pressure regulator all in one unit in the tank. This feeds the fuel rail which then feed the injectors. The LS1's fuel pressure at the rail at idle is ~58psi. The level sender goes to the pcm which then feeds the cluster. I would have to look it up but I'm pretty sure your 02 has 26.6lb injectors. Not really sure what else you might be looking for but if you'd post up a little more detailed info I'm sure someone here could give you a hand. The only literature I have on the fuel system are just schematics out of a haynes manual.
    Jan 2008
    Tucson, AZ
    Puter
    2002 Z28
    Here are some of my questions, right after the fuel pump there is a tee. Fuel filter feeds one end, the other end goes to the engine, the center of the tee goes back to the tank. Is the tee really a regulator, or is there a regulator somewhere else? Between the fuel rails there is a part that looks like an accumulator or regulator of some kind. I think the fuel line goes to it and it feeds the rails. It does not look "replaceable." What it is? What regulates the fuel pressure at the rails?
    Al
    Simpsons Did it!! 98formy's Avatar
    Minnesota
    83 Z28 new project
    98 Formula WS7-sold:(
    That is the regulator. It is replaceable, I believe there is a metal retaining ring around it, take that off and it should come uot of there. ps, make sure you depressurize the system first with a rag or something and depress the shrader valve at the end of the rail.
    Quote Originally Posted by 2002Zapper View Post
    Al
    that's called a pulse dampener or surge regulator. The actual pressure regulator is in the tank and that controls fuel pressure at the rails.
    Minnesota
    83 Z28 new project
    I learned something new today, sorry for the wrong info.
    Quote Originally Posted by 98formy View Post
    you're not entirely wrong....on the 97-98 vettes that was a regulator.
    Jan 2008
    Tucson, AZ
    Puter
    2002 Z28
    So it is an accumulator. So how is the fuel pressure regulated? Or, a better question would be: How does the regulator in the tank work?
    Al
  1. Ls1 fuel system
    By Kyle77 in forum General Help
    Last Post: 03-03-2012, 07:43 AM
  2. Help: Fuel System for STS
    By 1slowbusa in forum Forced Induction
    Last Post: 03-13-2011, 10:02 AM
  3. fuel system
    By tk66k in forum Nitrous
    Last Post: 06-11-2008, 11:01 AM
  4. Fuel system
    By Footloose in forum External Engine
    Last Post: 08-31-2007, 01:29 PM
  5. Fuel System....
    By jmangler in forum LT1
    Last Post: 08-22-2006, 02:15 PM
