    Apr 2009
    Pennsylvania
    Fuel System for STS
    I am doing a STS system on my 2000 M6 camaro. What fuel pump/system do i go with to make 450-500 hp?
    Thanks,
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    I would suggest the Racetronix fuel pump with the wiring harness.
    Injectors should be around 60-lbs. Siemen are a good brand. Some people also use FAST.
    You might also want to consider using methanol injection.
    Apr 2009
    Pennsylvania
    Thanks,
    What methanol injection do you recommend. Also the kit comes with 42# green top injectors.
    AlkyControl - this is the only methonal kit I would purchase.
    Injector sizing:
    Flow Rate = (HP x BSFC) / (# of Injectors x Max Cycle)
    BSFC is "Brake Specific Fuel Consumption and on a F.I. application is generally said to be 0.55. For N.A. the standard figure is 0.45. Max duty cycle on injectors should be no more than 80%, or 0.80.
    If you use 500 hp the formula would be:
    Flow Rate = (500 x 0.55) / (8 x .080)
    Flow Rate = 275 / 6.4
    Flow Rate = 42.96 lb/hr injectors
    Assuming the horsepower level is accurate, it looks like 42 lb/hr injectors would be pretty close to borderline. Hope this helps.
    Apr 2009
    Pennsylvania
    Injector sizing:
    yes it has been alot of help
    thanks
    Senior Member JoshuaGrooms83's Avatar
    Lake Geneva, WI
    98 Trans Am
    Thts what im gonning with when i get around to doing my STS system. I was gonna do this before had but wound up doing supporting mods first. Next year i shuold be there
  1. Ls1 fuel system
    By Kyle77 in forum General Help
    Last Post: 03-03-2012, 08:43 AM
  2. fuel system
    By tk66k in forum Nitrous
    Last Post: 06-11-2008, 12:01 PM
  3. LS1 Fuel system
    By 2002Zapper in forum General Help
    Last Post: 01-15-2008, 07:49 PM
  4. Fuel system
    By Footloose in forum External Engine
    Last Post: 08-31-2007, 02:29 PM
  5. Fuel System....
    By jmangler in forum LT1
    Last Post: 08-22-2006, 03:15 PM
