Thread: 02 sensors
    Virginia beach
    SOM
    02 sensors
    If my rear 02 sensors are bad will that effect my acceleration or anything?
    Member firemedic0135's Avatar
    East Texas
    2000/Trans Am
    yes the PCM will adjust the AFR to try and correct the problem it sees.
    Virginia beach
    SOM
    PCM what AFR who? Sorry im a nub, I dont know what those are?
    Member 180ls1's Avatar
    San Diego (Poway)
    1998 Firebird Formula WS6
    Quote Originally Posted by Justin23454 View Post
    it is the front oney you should be worried about the rear ones monitor how the cats are doing for the most part
    East Texas
    2000/Trans Am
    PCM= computer
    AFR=Air fuel ratio
    no problem I still dont know alot of these abbr. I soend alot of time on google lol
    Basiclly your PCM looks at the exhaust before and after the catalytic converter using the o2 sensors.It determines if you are lean,rich or in the middle and adjusts the AFR accordingly
    If it see's something that is not right ,it adjusts your AFR to try and make the numbers right.It will continue to adjust these (on the affected side,Bank 1 driver side,bank 2 passenger side) until it cannot adjust them anymore or your maxed out.
    there may be others that can explain it better and if I am wrong they can correct me or help you out further.
    East Texas
    2000/Trans Am
    Quote Originally Posted by 180ls1 View Post
    that is correct.
    I no longer have rear o2 sensors.I had them deleted when I bought the car.
    You can delete them with a custom computer tune or with a handheld programmer.
  1. O2 sensors
    By c5z28 in forum Computer & Tuning
    Last Post: 10-06-2010, 01:35 PM
  2. O2 sensors
    By Soltakr in forum External Engine
    Last Post: 05-20-2008, 09:09 PM
  3. 02 sensors
    By 02sscamaro in forum General Help
    Last Post: 04-16-2008, 04:02 AM
  4. o2 sensors
    By ls1_02 in forum General Help
    Last Post: 01-10-2008, 08:51 AM
  5. Should I buy new sensors?
    By EastTNZ28 in forum General Help
    Last Post: 06-15-2007, 09:14 PM
