Results 1 to 20 of 20
Thread: O2 sensors
    O.C. California
    2002 Camaro SS (crashed)
    Question O2 sensors
    I have got some long Tube kooks with their y pipe, and the o2 sensors are rattling like crazy. Driving me nuts I have tried warpping them and bending the ring but nothing helps. Is there a brand that doesnt make any noise?
    Bragg NC
    Met. Sunset Orange
    01 SS
    rattling? Are they tight? bung's stripped?
    J
    15 sec. Oh yeah, its fast UTVols98's Avatar
    Forest Lake, MN
    maroon
    2000 Z28
    Sounds like the bung's stripped.
    O.C. California
    Stripped?! I hope not, this thing is brand new. (the y-pipe) Anyway to fix it or do I need a new x-pipe?
    Forest Lake, MN
    maroon
    2000 Z28
    I don't think you'll be able to re-thread the bung so you might just have to cut it out and then weld another bung, but I could be wrong.
    2000 Z28: Accufab 4150, Vic Jr. 150 shot, Patriot stg 2 heads, big cam, FLT Stg VI 4L60, S60 rear. Waaay more stuff to list. 3100 LBS.
    O.C. California
    CRAP..hmm they dont seem to be moving but the rattle when I bang on the exhaust pipe.
    (2002 SS 6spd) SLP lid & scoop,NX wet kit & maf, NGK-TR6,160',MSD,Kooks LT & y-pipe,SLP Dual center exhaust,cut-out,tuning SUSPENSION Chromoly k-member, Chromoly adjustable upper and lower a-arms,koni s-adj,Eibach sport springs,Wilwood brakes,SB,BSK,TA,TAB,SFC,PHB,ST,18x9.5&18x10.5, Nittos
    Member 89LX's Avatar
    East Coast North Carolina
    Navy
    2000 Z28 M6
    Sure it is 02?
    If they are screwed in tight I can not see how they (the sensing element) could rattle. The end of your 02 sensor would have to be broken and swinging internally in the breeze. Pull them out and take a look. If okay, your rattle has to be something else.
    2000 Z28 M6, SLP Lid, SLP Bellows, SLP UD,
    P&P Maf, TB By-Pass, PS Shorties, LS6 Intake, FAST 78mm TB, Hooker CB, Hurst Billet, Front Tower Brace, small 218/218....527/527....114 cam.
    337rwhp/348rwtq
    O.C. California
    good point, I'll have the o2 sensors pulled out and check if they shake.
    Forest Lake, MN
    maroon
    2000 Z28
    You sure it might not just be the exhaust rattling on something on the car.
    O.C. California
    Yea, check the whole things, from headers back. Knocking, pulling and pushing on everything to make sure nothing else was making noise. Its weird.. gets loader when I let off the gas.
    Forest Lake, MN
    maroon
    2000 Z28
    I still think it's the exhaust. Mine rattles on the chassis when I ease into the gas, but is fine when in WOT.
    mercersburg pa
    hugger orange
    2004
    I hate to ask, but are you sure a bolt or anything else didn't end up falling into the exhaust and is rolling around in there? lol I have a gravel floor in half of my garage and when I put my LT's on I got a few small stones in it...drove me nuts but I finally figured it out, pulled the mufflers off and got the stones out of them
    O.C. California
    Haven’t checked that yet, put I did pull the O2 sensor out. If you shake them they sound like a rattle. Check the computer and the sensor are working properly. Talked to a few exhaust shops and they said that over time or higher miles, the sensor can loosen up and make noise. "All the expanding and contracting from heat tends to cause this." I checked my local GM shop and DAMN these are expensive. $153ea for the primary and $160ea for the secondary. Called PEPBOYS theirs are $70ea but they don’t show different part number for the primary and secondary like GM does. Hmm, what do you guys think?
    Navy
    2000 Z28 M6
    All the Same?
    Last (and only) time I checked on ordering they were all the same sensor just different wire length with gave them a different P/N. I got my front/right from auto zone.
    O.C. California
    Good point about the wire length.. I have extention because of my headers so maybe I can get away with the front cheaper ones.
    Norcal
    1998 Formula
    Just to note, you'll notice a significant quality difference between the AC delco and the Pep boys cheap version. Especially on the wire shielding.
    O.C. California
    Yeah, I figured as much. I'm going with the Delco, they have lasted over 60k and have run the piss out of it including spraying them is N20 haha
    Norcal
    1998 Formula
    You can buy them on ebay in the buy it now section for like 95 each. Type in ls1 O2
    O.C. California
    here is an dumb questions, how many cats can on the stock 2002?
    mercersburg pa
    hugger orange
    2004
    should be two... I think
    my 04 gto has 1 on each bank then right behind each of them there was a resonater that from the outside looks almost identical to a cat... there are no dumb questions, trust me lol
  1. O2 sensors
    By c5z28 in forum Computer & Tuning
    Last Post: 10-06-2010, 01:35 PM
  2. 02 sensors
    By 02sscamaro in forum General Help
    Last Post: 04-16-2008, 04:02 AM
  3. o2 sensors
    By ls1_02 in forum General Help
    Last Post: 01-10-2008, 08:51 AM
  4. Should I buy new sensors?
    By EastTNZ28 in forum General Help
    Last Post: 06-15-2007, 09:14 PM
  5. 02 sensors
    By 35thAnniZ28 in forum Camaro / SS
    Last Post: 05-01-2007, 03:20 AM
