Results 1 to 20 of 22
Thread: Just got my TSP True Duals on
01-06-2008, 09:44 PM #1
And i thought they would of tucked up better, but seeing them I guess they couldnt. The driver side is touching frame rails in two spots, passenger side is good. the driver side muffler needed to have the corner BFH to clear fuel/brake lines. All in all, got it in, and have 1 7/8" clearance at the mufflers.
What kind of clearance do you all have???
01-07-2008, 02:33 PM #2
could you post pictures?
01-07-2008, 02:42 PM #3down with the lot lizards
- Dec 2006
- Pensacola
Red- 2001 Camaro SS A4
that doesnt sound right man...yeah can you post some pictures? I actually thought about getting this setup..ide like to see what it looks like under the car though first.
01-08-2008, 09:29 PM #4
I will post some pics hopefully wednesday, been busy. Here is a vid of the idle
www.kyfbodies.org/member/chrisv/idle2.mpg
01-08-2008, 09:35 PM #5
Shoulda asked first! Clearance is an issue.
01-08-2008, 09:36 PM #6
01-08-2008, 09:41 PM #7
01-09-2008, 05:09 AM #8
mines tucks up better then that does
01-12-2008, 11:10 AM #9Senior Member
- Jul 2006
- indiana
black, 05 Roush- black, 99 T/A WS.6
I have 3-4" clearance with mine. Initial install I had the x on incorrectly which gave me about 1" after looking at it I swapped it around and was much happier with 3-4". What brand Headers do you have, that may play a role in your clearance too, as some headers have clearance issues themselves.
01-12-2008, 11:51 AM #10
sounds real good though!!1
01-12-2008, 03:02 PM #11
I have the Jet Hots, but they are touching the floorpan up to the X pipe, no clearance issues except for the actual mufflers which are touching the tranny tunnel as well. My car is lowered with the prokit springs as well. I dont see how you have 4" of clearance at the mufflers unless you have different muffs then i do, cause mine are tounching the floorpan and you cant go any higher then that
01-13-2008, 09:51 AM #12Senior Member
- Jul 2006
- indiana
I have sweet thunders, i bet you have the dynomax bullets. My muffler is 3" diamater as the dynomax is like 3.5" The ones in Fabrizi's pix I believe are the dynomax.....see how the muffler is a little bit larger in diameter compared to the rest of the piping?
01-13-2008, 10:00 AM #13
01-13-2008, 10:04 AM #14United States Marine
- May 2007
- Kansas City, MO
Blazen Orange Metallic- 2006 GTO
If you have less than 4 inches of clearance, you did something wrong. Unbolt everything and try it again. *edit* Nevermind, you being lowered may have something to do with your clearance. The prokit probably dropped you nearly 2 inches, so you may not get any better than you are.
Here's mine:
Fabrizi, you've got to be able to get better clearance than that! I wouldn't even drive that car with that set up.Last edited by Kamauxx; 01-13-2008 at 10:11 AM.
01-13-2008, 10:06 AM #15
Lowered and on 16 inch wheels.
01-13-2008, 10:11 AM #16
I had clearance issues trying to keep the drivers side away from the fuel lines but I only have problems if I have 2 people in the back. So I just dont have any passengers unless I absolutly have to. Mine is the one on the right.
01-13-2008, 10:14 AM #17United States Marine
- May 2007
- Kansas City, MO
You can move the fuel lines up to one of the higher holes in the plastic bracket. Tha'll keep em a good .5-1" away from the exhaust.
01-13-2008, 10:16 AM #18
01-13-2008, 01:26 PM #19
01-13-2008, 02:15 PM #20
true duals
By Blackbird WS6 in forum General HelpReplies: 6Last Post: 04-18-2011, 09:40 PM -
TSP true duals
By Same ol Situation in forum Firebird / WS6Replies: 10Last Post: 03-04-2011, 10:15 PM -
True duals
By Tx98Formula in forum External EngineReplies: 6Last Post: 04-19-2010, 05:24 PM -
true duals
By joker in forum DrivetrainReplies: 3Last Post: 08-20-2007, 03:55 PM -
True Duals?
By joker in forum Firebird / WS6Replies: 3Last Post: 07-01-2006, 07:17 AM
