Results 1 to 11 of 11
Thread: TSP true duals
    Bullet Boy Same ol Situation's Avatar
    Dec 2008
    Cincinnati, Ohio
    2002 CETA m6
    TSP true duals
    Looking to put this setup on my car in the spring, is there anything specific i need to know about the install? and will there be any clearance issues?
    Jul 2009
    North of the Motorcity
    Custom Swirly Black
    2001 WS6 M6
    Dumping before the axel?
    If not, you'll need to relocate the panhard bar to make life alot easier.
    blah '02 WS6's Avatar
    white deer, tx
    '02 trans am ws6
    Make sure you H-pipe isn't upside down or it'll hang really low. Flip the fuel line bracket to gain some clearance when you install them. X2 on the PHB relo, unless you run them under-axle or want to go down to 2.5 od to go over-axle, after that it's a matter of how good your exhaust guy is.
    '02 ws6.....mods? nope
    Dec 2008
    Cincinnati, Ohio
    2002 CETA m6
    Would plan on dumping after the axel. Is true duals worth the trouble for the sound and hp gains?
    white deer, tx
    '02 trans am ws6
    I never considered any hp gains with exhaust...only sound...and I chose TSP TDs with bullets.
    Dec 2008
    Cincinnati, Ohio
    2002 CETA m6
    I gotcha, how is the sound?? I know that cold start ups are extremely loud. I was considering the system with the sweet thunder mufflers myself
    white deer, tx
    '02 trans am ws6
    Go to youtube and search my username (yeti8102) I have vids on there of what mine sounded like. I also have my buddies z28 with sweet thunders on there racing a Lightning as well. That should help give you an idea of the differences. I would embed the vids here but I can't do it through my phone and Tapatalk.
    Member ls1wallen's Avatar
    Jul 2009
    Saint Peters, MO
    2001 Formula
    Just a warning if you go with a cam later. It will be ear bleeding loud!!!
    2001 Formula ported and polished throttle body, Lid, Longtube headers, texas speed true dual, cam is the texas speed 228r 228/228 588. lift 112 lsa, tuned by Frost
    Member Eganslp's Avatar
    Oct 2009
    Philadelphia
    Sunset metallic orange
    '01 Camaro SS
    here's a vid of mine dude!!! it's a cold start through SLP LT's to TSP X-pipe to moroso spiral flows dumped be4 axel.
    [ame]http://www.youtube.com/watch?v=lgA9COeSoJY&feature=youtube_gdata_player[/ame]
    [ame]http://www.youtube.com/watch?v=t45xZme3fIo&feature=youtube_gdata_player[/ame]
    Note; if you do plan on doing this you can't use a crossmember T/A. It has to be a trans mount or the trans mount relocation bracket setup (to get it off the trans). The only downfall of this is how long your T/A will be. You get better traction with a shorter one, but to each his own. Right now I'm currently running the jegster T/A tunnel mount "Don't Buy That One" it's garbage plus it doesn't adj. Also you have to drill like 14 (3/8") hole in the tunnel to mount it. So plz learn from my mistake. hope these vidz helped
    Sent from my iPhone using Tapatalk
    The sound of your piss hitting the urinal.......yea it sounds feminine!
    Jul 2009
    Custom Swirly Black
    2001 WS6 M6
    Quote Originally Posted by Same ol Situation View Post
    HP gains for a TD setup on a stock motor vs y-pipe are very minimal from what I've heard.
    Junior Member RamAM02's Avatar
    Mar 2011
    OKC,OK
    2002 Trans Am
    I have heard the same unless you are doing a lot of engine mods. That's when the x really comes into play.
  1. true duals
    By Blackbird WS6 in forum General Help
    Last Post: 04-18-2011, 08:40 PM
  2. True duals
    By Tx98Formula in forum External Engine
    Last Post: 04-19-2010, 04:24 PM
  3. LT's and true duals?
    By BlueBomber in forum External Engine
    Last Post: 08-23-2007, 08:14 AM
  4. true duals
    By joker in forum Drivetrain
    Last Post: 08-20-2007, 02:55 PM
  5. True Duals?
    By joker in forum Firebird / WS6
    Last Post: 07-01-2006, 06:17 AM
