11-28-2005, 04:54 PM #1I like the way yew tawlk.
- Blairsville, GA
Red- 2000 T/A WS6
Tire wear on edges at 36psi... WTF???
As you can see, I don't know what's causing BOTH edges of EACH front tire to continue to wear with the middle being okay. It all started with a 40 min mad blast from Blairsville, GA to Cleveland, TN(anyone who lives in the GA/TN/NC area knows it) to pick up something at the FedEx hub before it closed. Stopped at the first air line I could and put in 32 psi. Sometime later, still wearing on the edges. I put 36 psi in(the tires go up to 44, so I don't worry bout overinflating them yet). A few weeks later, they're STILL wearing on BOTH edges of the front tires! Could an out-of-line front end cause this??? I'd think it would only cause ONE edge to wear, not both.
To add to the confusion, the rears are at 24 psi, and wear perfectly. Surely, the car isn't that nose-heavy, is it???
11-28-2005, 06:23 PM #2Detailing + Design
- Pittsburgh, PA
sounds like you have a SERIOUS allignment issue, my freind...if anything your 2 front tires look like this: \ /
11-28-2005, 09:27 PM #3I like the way yew tawlk.
- Blairsville, GA
Red- 2000 T/A WS6
That's what I thought at first, but then that would only wear here--> \ / <-- and not here -->\<-- -->/<--
Does that make sense at all???
11-29-2005, 04:21 AM #4Junior Member
To much air, try 30 psi front 28 psi rear. That's what i run on my 285's
Hawk
11-29-2005, 07:42 AM #5
too much would wear the middle. i'd check your sidewalls for inflation info, then get it aligned, and if that didn't do anything, just pump it up til the don't do it anymore
11-30-2005, 05:35 AM #6Junior Member
Originally Posted by Mr. CarelessAndImprudent
Beer does hamper my ability to operate a key board.
11-30-2005, 06:56 AM #7
Alignment most definately. It will cost you but it will fix the problem.
11-30-2005, 07:24 PM #8I like the way yew tawlk.
- Blairsville, GA
Red- 2000 T/A WS6
I looked today, and it's wearing considerably on the outer edge of the tires, so... yep, need an alignment. Thanks, y'all.
Does this looks like out of the normal tire wear?
By JayTA98 in forum Wheels and TiresReplies: 6Last Post: 05-22-2013, 05:29 AM -
tire wear
By cobra12345 in forum General HelpReplies: 5Last Post: 08-12-2007, 02:57 PM -
Tire Wear
By jroc in forum Firebird / WS6Replies: 10Last Post: 12-30-2006, 04:17 PM -
Uneven tire wear on rear tire??
By renzo in forum Wheels and TiresReplies: 2Last Post: 11-20-2006, 04:30 PM -
Tire Wear
By SailorZ28 in forum Wheels and TiresReplies: 12Last Post: 03-22-2006, 05:33 PM
