05-16-2013, 05:26 AM #1
Does this looks like out of the normal tire wear?
Hi guys, my front tires are going to be replaced in june. they are getting low on tread and have some dry rot as you can see. I have noticed this excessive wear on the ends of the tire on each side on both front tires. Tires are michelin pilots a/s. There is no play at 9-3 or 12-6 when I move the wheel so i know upper and lower ball joints are good. Same goes for tie end rods and hubs. The car is lower in the front with blistein hd's and eibach springs. I also have poly sway bar end links. The car was aligned after it was lowered and every 6 months i get it rechecked. I check the air pressure in the tires every 2 weeks and i keep them at 35-40 psi.
I do know that this wear can be caused by hard cornering (which I might have done when i had the tires new) but i don't drive aggressive all the time and i try to limit that as well. The sway bar bushing have never been replaced. Sway bar is OEM factory one.
So as the tires get old is it normal to see this wear? Could this be caused by the car been lower at the front? I looked at the wheel wells and i don't see anywhere the tires rubbing against it. The rear tires are fine.Thanks.
05-16-2013, 05:48 AM #2Former Mopar Man
- Jun 2011
- Branchville, NJ
Pattern looks normal for your type of driving. The marks on the inner and outer part of the tire is not wear but scuffing from hard driving.
05-16-2013, 05:59 AM #3
05-17-2013, 07:29 PM #411 years of bangin gears
- Jan 2009
- North Jersey
Agreed. If it were from underinflation, the outsides would be way worse.
05-22-2013, 04:34 AM #5
05-22-2013, 05:27 AM #6
05-22-2013, 05:29 AM #7
tire wear
By cobra12345 in forum General HelpReplies: 5Last Post: 08-12-2007, 02:57 PM -
Will upper A arm to fix uneven tire wear?
By sic2001 in forum General HelpReplies: 4Last Post: 04-07-2007, 02:56 PM -
Tire Wear
By jroc in forum Firebird / WS6Replies: 10Last Post: 12-30-2006, 04:17 PM -
Uneven tire wear on rear tire??
By renzo in forum Wheels and TiresReplies: 2Last Post: 11-20-2006, 04:30 PM -
Tire Wear
By SailorZ28 in forum Wheels and TiresReplies: 12Last Post: 03-22-2006, 05:33 PM
