    bay area
    1999 Hardtop Z28
    Weird Vibration at deceleration
    ive been trying to diagnose this vibration ive had since my clutch install. it happens the most when decelerating from 60+mph. feels like its coming from right under the shifter, but the shifter isnt shaking that bad. i also put in a poly trans mount, but its been about 1500miles, so i woulda thought it was broken in...any ideas?
    IL
    06 HD Softail
    1998 Trans Am m6
    have you had your tire balanced lately?
    bay area
    1999 Hardtop Z28
    Quote Originally Posted by hutch1999 View Post
    first thing i checked. tire pressure, made sure the mount was bolted tight, took out the driveshaft, couldnt find anything major looking wrong with it....im stumped lol
    Senior Member 01ws6er's Avatar
    The 717
    2001 Trash Can
    Quote Originally Posted by Loudz28 View Post
    Already took out the driveshaft? Shouldn't be that hard to take it out again and get it balanced lol. Did you make sure you put your driveshaft in the exact same way as you took it out (when you did the clutch) because that could cause vibration (due to it getting torqued on for all those miles before you took it out) and when you replace it a different way, it will be out of balance. Did it in a truck of mine when I did the clutch. The fucker fell out on the road and shattered the back of the shaft.
    If you did something when you installed the clutch, i.e: put stress on the new clutch disk/ plate when sliding in the tranny, that could cause a problem as well, but I think that would result in slippage more so than vibration.
    bay area
    1999 Hardtop Z28
    hmmm i had aamco due the clutch, i kno i kno bad choice. ive heard it before and im on my 2nd clutch with them. im starting to think that they just fucked up in the installation. again.
    Internet Tough Guy Fury_786's Avatar
    Oregon
    Sinister, SixGun
    2001 SS, 2002 L36 M5
    are your wheels strait? one or more may be warped. i had that happen to mine, and it did the exact same thing.
    however, poly trans mounts, especially when you have some good LCA's, tend to make everything vibrate like hell.
    bay area
    1999 Hardtop Z28
    Quote Originally Posted by Fury_786 View Post
    straight u mean not bent? or alignment?
    Oregon
    Sinister, SixGun
    not bent some people call it warped.
    its really easy to do to an alum wheel.
  1. Weird vibration
    By kmassner in forum General Help
    Last Post: 10-21-2012, 10:08 AM
  2. Help: weird vibration when the t/a is warming up
    By ggino85 in forum General Help
    Last Post: 07-24-2008, 11:30 AM
  3. Smoke on deceleration; why?
    By Sam-SS in forum General Help
    Last Post: 10-10-2007, 01:09 AM
  4. Really bad rattling sound upon deceleration.
    By zratedss in forum External Engine
    Last Post: 09-28-2007, 12:42 AM
  5. Weird Vibration
    By pontiac_god in forum Drivetrain
    Last Post: 09-05-2006, 05:59 PM
