Results 1 to 17 of 17
    zratedss
    Guest
    Really bad rattling sound upon deceleration.
    When I accelerate and then let off the gas, as the rpms come back down or when i push the clutch in to shift (especially when the rpms come back down) there is a really loud rattle coming from the exhaust. It rattles until the rpms are all the way to idle or until i start to accelerate again. There is no rattle when im accelerating or when at idle.
    Could it be the cat converters? My car is only a 2002 SS and I just hit 40,000 miles. I wouldnt think it would be the cats. Anyone else have this problem? Any suggestions? Please help me out. Thanks everyone.
    Jesus died to save you! Killer_bluebird's Avatar
    North Olmsted, OH
    Any Mods? Mine rattles at low RPMs because my Y-pipe is slightly touching my Driveshaft loop. Here are other things that tent to rattle: Seatbelt fasterner on the passenger seat, and the Pull out Cup holder bottom wire, This is mostly due to the problem above. The exhaust is sending the vibrations trought the trans tunnel mounts and into the body. I haven't gotten a chance to fix it yet.
    2000 NBM Camaro Z28
    Mods:
    SLP Lid & K&N, AHR Headers + 3" catted Y and Mangaflow, !EGR, !AIR, BMR CM STB, ST Front 35mm and Hellwig Adj. Rear 22mm Swaybar, Adj. Rod/Rod PHB, Koni SA's, Ground Control Springs & Adj. Ride height, and HPTuners.
    Fort Worth, Tx
    2001 Formula Firebird
    Also check to make sure there isn't a broken weld on the cat heatshield.
    Had that problem on my truck....
    Can you tell if it's more towards the front or rear of the vehicle?
    zratedss
    Guest
    hhmm not sure but it definitely isnt anything on the inside of the car. I had my girlfriend drive my ss while i was driving my Z28 next to her towards the rear quarter panel and the rattle noise is loud from the rear. Everytime the rpms come back down and when she shifts it rattles until the gas is stepped on. Damn, i wish i could figure it out because it really sounds like crap. im hoping its just that the cats are bad. But at 40, 000 miles? Thanks for the input and i will definitely have the heat shields checked out.
    Thanks.
    zratedss
    Guest
    Ok guys, I found a sound clip of a LS1 WS6 with only the loudmouth and everything stock like mine. You can hear the rattling upon deceleration. It sounds exactly like my ss. Tell me what u guys think and how the hell do i get rid of it. Thanks everyone.
    LM Sound clip with rattle
    CamaroSSx1999
    Guest
    i dont hear what ur talking about, but i hear kind of a deep muffle after he lets off, if thats what ur talking about.... pretty sure thats normal, b/c i have it too.. but i have a cutout,
    zratedss
    Guest
    no its after the deep muffle or right after the "growl." right before the revs go back to neutral. or should i say it this way...after the rpms are all the way back down. its right after the growl then right before it goes back to idle there is the tin can rattle noise.
    i dont know if im making any sense but thats the best way i can explain it. sorry.
    thanks for the input though.
    zratedss
    Guest
    anyone else hears the rattle im talking about? please any help would be great.
    AmG
    Guest
    I know what your talking about, I had it on my 2000 Z28 and now on my friends 1999 Trans Am, its annoying, and I'm trying to find it, no luck yet. It's in the back though and I don't think its form the pipes.
    -AmG-
    Senior Member MadSeason's Avatar
    Indiana
    I have it too, it's just the harmonic from the engine rpm created with the LM muffler
    AmG
    Guest
    Lm?
    Indiana
    lm = loudmouth
    AmG
    Guest
    The car is stock, it doesn't even have an airfilter on it, and its driven around 122,000 miles
    -AmG-
    Indiana
    i'm trying to help out zratedss. its his thread and he has the LM exhaust
    zratedss
    Guest
    thanks for trying to help guys. like i said i took it to two muffler shops and they both said that it was the loudmouth because the lm acts like a straight through pipe so since there is not much back pressure, its sucking back air from the tailpipes and thats whats making the noise. thats what the muffler guys told me.
    anyway, if you guys find anything else out please let me know. thanks for everyones input.
    fl
    My over axel pipe rattles against the heat sheilds. I've got the 3" corsa setup and its just to tight back there. I'm thinking about wrapping the pipe with some exhaust tape. Any opinions on that? That should solve the metal/metal rattle.
    australia
    2002 holden calais gen111
    i have the same year car and i have exactly the same problem, my rattle noise on deceleration happened after i had 4in1 pacemaker headers fitted,all i can think of is that one of the cats were damaged when they shortened the pipes to take off the restrictive bends in the stock pipes, ive spent loads of money on the car and its gonna have to wait! somebody also mentioned a possible differential problem.
  1. Chattering/rattling sound. Possibly in my clutch?
    By LS1nterceptor in forum Drivetrain
    Last Post: 08-12-2008, 08:38 PM
  2. Clutch Rattling Sound
    By Rhinohuey in forum Manual Transmission
    Last Post: 05-03-2007, 01:47 PM
  3. Weird Rattling Sound??
    By NiteRiderWs6 in forum General Help
    Last Post: 04-26-2007, 03:48 PM
  4. rattling sound on takeoff? (95 T/A)
    By Followthehollowx in forum Manual Transmission
    Last Post: 12-05-2006, 11:29 AM
  5. Weird rattling sound near redline?
    By big_hink in forum General Help
    Last Post: 07-24-2006, 08:53 AM
