Results 1 to 19 of 19
    Senior Member kool-aide's Avatar
    Deltona, FL
    Sebring Silver Metalic
    2002 Camaro Z28
    After market radio w/ steering wheel control?
    what after market in dash radios would have some kind of remote that would work with the steering wheel controls?
    thanks
    kool-aide
    IL
    06 HD Softail
    1998 Trans Am m6
    man i think your pretty much SOL once you put and aftermarket head unit in your steering wheel controls are junk
    Deltona, FL
    2002 Camaro Z28
    really? I've heard in the threads about radios that can use a remote adapter thingy and program it up. The reason for the post is I have read about it, but haven't found any model numbers on radios.
    Member 01pewterZ's Avatar
    TEXAS
    Light Pewter Metallic
    2001 camaro Z28
    Cool
    i heard you can also use steering controls with an aftermarket cd player. go to www.crutchfield.com
    TEXAS
    2001 camaro Z28
    Deltona, FL
    2002 Camaro Z28
    thanks
    Deltona, FL
    2002 Camaro Z28
    now i'm searching for a wiring diagram for a 99 camaro that will help me create a custom harness for adding the controls. I checked the sticky and there is only one wire in the diagram but my connector has four, hmm... I never realized how much effort adding the radio controls would be.
    IL
    06 HD Softail
    1998 Trans Am m6
    Quote Originally Posted by kool-aide View Post
    Yea thats why I said your SOL, but good luck man
    Deltona, FL
    2002 Camaro Z28
    Quote Originally Posted by hutch1999 View Post
    now that i am paying attention, got it. Yeah, this seems like such a great idea, in my head.
    Mike The Guz's Avatar
    Lawndale, CA
    Artic White
    2002 Camaro SS
    You should be able to use a device from pac audio to retain your steering wheel controls. They make some for alpine, pioneer and others. You will have to check their site. Google pac audio. I am running the pac swi-x with a clarion headunit.
    2002 Artic White SS 35th Wheels|Full Hotchkis Suspension|Koni SA|Magnaflow CME|SLP lid|www.fquick.com/The_Guz
    Even Bandit Is Jealous mpunklil's Avatar
    San Juan Capistrano, CA
    2004 Cadillac CTS-V
    Quote Originally Posted by The Guz View Post
    how about some quicky wiring color codes i'll be changing my radio soon
    Feb 2006
    Orange County, NY
    always dirty
    2013 Ram 2014 Caddy ATS
    In the haynes manual it only lists 4 wires for the steering wheel controls.
    black- ground
    dk blue- to radio, controls volume
    grey- lights for controls
    yellow- power
    Deltona, FL
    2002 Camaro Z28
    thanks for the colors, now that takes care of the four wires in the column. The big question is what pin outs do they go to in the back of the radio harness?
    2004 Cadillac CTS-V
    so it is a data bus then? because there are 6 other buttons besides volume up and down
    Deltona, FL
    2002 Camaro Z28
    that is what i would assume. i would assume it is reading the voltage to figure out what it needs to do. you have four wires and more than four buttons. so that's where i was heding with the whole thing. the main problem is matching the column wires to some where in the car. i assumed all for connected to the main radio harness. now i am not so sure. i'm kind of out on a limb and no references, just scratchin my head.
    Lawndale, CA
    Artic White
    2002 Camaro SS
    There are many options available. The SWI-X uses three wires. Power, ground and the wire for the steering wheel controls. You can also email them and find out if your headunit is supported and what adapter you can use.
    http://www.pac-audio.com/products/pr...el%20Interface
    Deltona, FL
    2002 Camaro Z28
    thanks
    Deltona, FL
    2002 Camaro Z28
    well i am done
    i added to this thread on how i made out on adding steering wheel radio controls and a new fuse box circuit thingy
    http://www.ls1.com/forums/showthread.php?t=70006
    it was a ton of fun, even in the freeze FL winter weather.
    Deltona, FL
    2002 Camaro Z28
    oh, and thanks to all and all that helped, it was smooth sailing once i got the parts
  1. Steering wheel radio control wiring???
    By Piranhaz in forum Stereo and Electronics
    Last Post: 10-08-2009, 12:14 PM
  2. Steering wheel radio control light fix
    By 0rion in forum General Help
    Last Post: 06-09-2008, 01:12 PM
  3. Steering Wheel Radio Control Wiring
    By kool-aide in forum Stereo and Electronics
    Last Post: 01-02-2008, 11:46 AM
  4. steering wheel w/ radio control
    By apss in forum Parts For Sale / Trade
    Last Post: 01-10-2007, 06:29 PM
  5. Steering wheel radio controls for 99 T/A
    By blackTA6585 in forum General Help
    Last Post: 01-06-2006, 02:17 PM
