Results 1 to 20 of 21
    Steering wheel radio control light fix
    Since I see this from time to time in here I thought I'd sticky the site that has the instructions on fixing this problem.
    Radio Controls light fix
    Mountville , pa
    2000 camaro
    burned out
    thanks for the help on this . but i have more then one lamp in mine .
    Impwnded Smkn_TA's Avatar
    Davenport, Iowa
    Bright Red
    1999 Trans Am Ws6
    Did not even know they were supposed to light up until I chanced upon this thread. Went to radio shak and they had to order the bulbs. Must not be an item they sell a lot of. One on the shelf looked like it had been there since edison invented it.
    Davenport, Iowa
    Bright Red
    1999 Trans Am Ws6
    Did this over the weekend last night...long story short, the wires are ridiculously short, got them out, no way to get them back in. I ended up pulling out the airbag, after that it was a cake job!
    Mountville , pa
    2000 camaro
    glad it all worked out for ya . ya the wire is short !!
    Junior Member fbody01's Avatar
    orlando
    2001 Firebird
    i didnt either. does any one know if the power windows, mirrors and door locks on the door panel are supposed to light up too??
    2001 Pontiac Firebird
    3.8L V6
    5-spd
    Mountville , pa
    2000 camaro
    on my 2000 camaro there is a little light that glows down on them
    hope this helps
    i need help on the abs break light thats on ? i put a new unit on the hub but it didn't change anything . even though thats what the chevy dealer told me .
    Quote Originally Posted by yodabill View Post
    hope this helps
    please start a new thread for this so the sticky doesn't get side tracked.
    Preferred Member CWW17's Avatar
    Central Illinois
    Black | Black
    '07 Z06 | '98 WS6
    This fix did not help me. Then I tried replacing the whole control, Didn't work either. So it must be my wiring then? Anyone else have or solved this problem?
    Beaver Dam KY
    79 T/A -91 Firebird
    1998 Trans Am -Oynx Black
    None of my lights works.. havent replaced them yet. All the fuzes are good. What could be the problem??
    Mountville , pa
    2000 camaro
    you may just need new ones . i tryed the new bulb . but that was not the way to go in my case . so i just got a whole new one . it took me less then 15min to switch out the old to the new (the wire hook up is real short no joke ) that was the hardest part to the whole job. good luck
    bill
    Junior Member Raleigh TA's Avatar
    Raleigh, NC
    Blue on white
    1999 Trans Am
    Ground?
    I have similar lighting issues, it has been suggested that I may have a ground issue. I have not attempted to trace it. My display on my Monsoon, my odometer, and trip meter, and sometimes a tail light are off most of the time.
    Member TopForm11's Avatar
    Chicago
    2002 Trans Am WS6
    Thanks...helped me
    Indiana
    94 Pont. Firebird Formula
    got any write ups for the lt1 controls? i am in need so i can turn my bulbs blue
    Quote Originally Posted by squeals99 View Post
    no, but I would assume they were very similar. Probably just have to switch to a blue led.
    Corinth Mississippi
    2000 Camaro SS M6,3.42's
    Quote Originally Posted by Raleigh TA View Post
    Had a similar problem with my 2000 SS dash lights and monsoon display would not work. Checked and fuses were good. Replaced them with new ones anyway and now they work. Sweet!
    San Diego
    1999 Trans Am
    I've had it out for weeks now since I couldn't get it back in with the ridiculously short wires. How can one remove the airbag without having it go off? I would really like to get the controls back in.
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    I usually use a hooked pic (the 1st one on the left in pic) to grab the connector and guide it into the switch.
    Single Malt rbob93's Avatar
    Ft. Lauderdale, FL
    Sebring Silver
    2000 CamaroSS
    I used a big paper clip bent to a similar shape
    San Diego
    1999 Trans Am
    That is cool, thanks!! I guess once I guide it into place, then it will click into the clip as I push it into its space
  1. Steering wheel radio control wiring???
    By Piranhaz in forum Stereo and Electronics
    Last Post: 10-08-2009, 12:14 PM
  2. Steering Wheel Radio Control Wiring
    By kool-aide in forum Stereo and Electronics
    Last Post: 01-02-2008, 11:46 AM
  3. After market radio w/ steering wheel control?
    Last Post: 01-02-2008, 11:45 AM
  4. Cant Fix Steering Wheel Control Light...?
    By CWW17 in forum Stereo and Electronics
    Last Post: 03-27-2007, 09:09 AM
  5. steering wheel w/ radio control
    By apss in forum Parts For Sale / Trade
    Last Post: 01-10-2007, 06:29 PM
