    dallas
    green
    1998 trans am
    Throttle Body Fast Probblems
    WELL TRIED TO TURN OFF BATTERY WHEN INSTALLED IT TURNED ON LET CAR IDLE THEN TURNED IT BACK OFF FOR A MINUTE THEN IT IDLED FINE TOOK IT FOR A RUN AND THE TRANSMISSION WAS SHIFTING WAY TO SOON SO I KNEW IT WAS NOT WORKING RIGHT SO BUT STOCK BACK ON IT RUNS OK ANY BODY HELP HATE TO SPEND 400 BUCKS AND NOT GET TO USE IT WHAT NEEDS TO BE DONE WHAT WOULD A CUSTOME TUNE DO WILL A HYPERRTECH POWERPROGRAMMER WORK TRIED IT IT DID NOT NEED HELP ANYBODY PLEASE
    Member camaross19973's Avatar
    Los Angeles
    blue
    1999 camaro ss #976
    did u hook the cable back to were they belong.
    dallas
    green
    1998 trans am
    There Is Two Hole In The Fast Tb Were The Cable Can Go It Will Only Go In The First One And It Is Firm And I Give A Little Gas The Butterfly Moves If I Floor It It Opens Wide Open
    you could try to do an idle relearn. Set the emergency brake and let it idle in park with a/c off for a few minutes then in park with the a/c on for a few minutes then in gear with a/c off and with a/c on. Doubt that'll fix it but it's something you could try. Did you make sure that you got the bellows back on good and there are no air leaks post MAF?
    Senior Member Wheeler99WS6's Avatar
    indiana
    black, 05 Roush
    black, 99 T/A WS.6
    did the fast TB come with new sensors or are you swapping in your stock sensors?
    dallas
    green
    1998 trans am
    it came with some buti tried them and the old ones same result
    indiana
    black, 05 Roush
    black, 99 T/A WS.6
    what size TB is it?78mm or 90mm?
    dallas
    green
    1998 trans am
    78mm
    indiana
    black, 05 Roush
    black, 99 T/A WS.6
    huh......I honestly would of figured that the 78mm would bolt up with no problems.
  1. WTB Fast 78mm throttle body
    By 1fastirocz in forum Parts Wanted / Trade
    Last Post: 11-08-2010, 10:43 AM
  2. Fast Intake and Throttle Body
    By 98Z28CamaroJG in forum Parts Wanted / Trade
    Last Post: 04-12-2010, 08:01 AM
  3. Question: 78mm FAST Throttle Body
    By 98maro in forum General Help
    Last Post: 03-04-2010, 11:27 AM
  4. Question: FAST 78mm Throttle Body?
    By x10-wakerider in forum External Engine
    Last Post: 06-07-2009, 09:01 AM
  5. FAST Throttle Body
    By speedkills in forum General Help
    Last Post: 01-10-2007, 07:29 PM
