Results 1 to 20 of 20
Thread: Fast Intake and Throttle Body
03-29-2010, 11:10 AM #1
- Nov 2009
- Altoona and Downingtown, PA
- iTrader
- 0
Black- 1998 Z28 and 67 Firebird
Hey guys, i'm looking to start doing some upgrades, so intake and tb are next on my list. Any idea where i can get a Fast Intake and Throttle Body Combo for a cheap price? I can't spend ANY over 1000, i'm trying to find it for 800 or 900. 90/90...92/92...102/102, whichever haha. Any sponsors on here have any cheap prices by any chance?
03-29-2010, 11:36 AM #2
- Jan 2006
- Shepherd, Michigan
- iTrader
- 1 (100%)
well let me help you out...the 102mm is for ls1/ls3 etc heads...so your gen III heads will not mate.
the fast 90 is solid..the 92 is the updated but no noticeable gains really...now..the fast 90 TB has some issues with throttle(blade) sticking..so stay away..that issue has been fixed with the 92s tb...nick williams TBs are considered the best ..so look into them instead of fast's TBs if you can.
now for the big thing. the fast 9x series intakes will not net you a huge gain over the ls6 until you decide to go with a mild to extreme cam...of course multiply that a set of heads...so depending on your goals a 300 dollar ls6 intake might be a better choice.
03-29-2010, 11:36 AM #3
- Jan 2006
- iTrader
- 1 (100%)
now before i forget...what are your other mods ?? if none...i can think of about 10 things better to buy for your car under 1000 than the fast ...
03-29-2010, 05:17 PM #4
- Nov 2009
- iTrader
- 0
Can 92 TB's go on the 90 Intake's? I plan to eventually have a HCI swap or a stroker motor, so i'm just getting all the supporting mods right now. After the Intake and TB, Pacesetter Race LT's and TSP ORY are next on the list, followed by further suspension mods. Here are the mods i have now.
Whisper Lid, Smooth Bellows, 85mm MAF, Koni Single Adjustable Front Shocks, Bilstein Rear Shocks, Thicker Front and Rear Sway Bars, B&M Short Shifter, Centerforce Stage 2 Clutch, Fidanza Aluminum Flywheel, Loud Mouth 1 Cat-Back, Firehawk Wide-Oval Street Tires.
03-30-2010, 06:56 AM #5
- Jan 2006
- iTrader
- 1 (100%)
well then go ahead and get the intake stuff..but be warned ...depending on what stroker engine you go with ...you might not be able to use the fast 9x series ..for example ..if you go with a ls3 stroker etc..the fast 9x wont work..i also am 90% sure (no pun intended) that the 92 will mate to the 90.
03-30-2010, 07:30 AM #6
- Nov 2009
- iTrader
- 0
thanks for the info. I was thinking about going with the LS2
03-30-2010, 08:41 AM #7
03-31-2010, 04:08 PM #8
- Mar 2008
- Goose Creek, SC
- iTrader
- 0
Victory Red- 2002 T/A WS6 A4
WRONG!!!! They have both applications available. check out FAST p/n 146302
http://www.fuelairspark.com/2/FS/Intake/Default.aspx
03-31-2010, 06:00 PM #9
04-01-2010, 03:27 PM #10
- Mar 2008
- Goose Creek, SC
- iTrader
- 0
just want to help with my .02 to get the right info out here in the forum. helps everyone out in the long run.
04-01-2010, 05:09 PM #11
04-05-2010, 08:06 AM #12
- Nov 2009
- iTrader
- 0
Is the 102 worth the extra money over the 92? I've just got a stock motor right now, and will for a few more years
04-05-2010, 09:00 AM #13
04-05-2010, 09:10 PM #14
- Nov 2009
- iTrader
- 0
what would you recommend? save for heads/cam...engine has 135xxx miles on it and don't have the money for that.
04-06-2010, 09:55 AM #15
- Jan 2006
- iTrader
- 1 (100%)
exhaust first.
after exhaust then look into fast if you want..or go with a ls6 intake right now ...buy it for 300-400 and run it for a few years until your head and cam combo is ready..then sell the ls6 manifold for 300-400 dollars.
worth noting also...what type of stroker are you planning ? as in what platform you going to run...as that will dictate what heads and especially what intake you will buy.
04-08-2010, 08:03 AM #16
- Nov 2009
- iTrader
- 0
I already have a cat-back, and LT's and ORY are going to be bought at the same time as the Intake and Throttle Body, along with SFC's. As for the stroker, i'll probaly be getting a 402/408
04-08-2010, 11:12 AM #17
- Jan 2006
- iTrader
- 1 (100%)
the problem you will run into is buying the top end for the 402/408 and trying to get them to work well with a 346. as most heads for 402/408 strokers require a 4.010 ish bore ...and the 346 you have 3.898.
and obviously specing a cam for a 402/408 will not be optimal for a 346.
04-08-2010, 06:37 PM #18
- Nov 2009
- iTrader
- 0
that sounds crappy. what stroker would you commend? 383?
04-09-2010, 05:07 AM #19
04-12-2010, 08:01 AM #20
- Nov 2009
- iTrader
- 0
hmmm. I'm in college with not the most of money...sooo how much do they run?
WTB Fast 78mm throttle body
By 1fastirocz in forum Parts Wanted / TradeReplies: 2Last Post: 11-08-2010, 10:43 AM -
Question: FAST 78mm Throttle Body?
By x10-wakerider in forum External EngineReplies: 2Last Post: 06-07-2009, 09:01 AM -
Throttle Body Fast Probblems
By noearriaga in forum General HelpReplies: 8Last Post: 12-28-2007, 04:44 PM -
New 90MM LSX Fast intake & New Nick Williams 90MM Throttle Body for LS1 $1000.00 &shp
By harnick3 in forum Parts For Sale / TradeReplies: 5Last Post: 07-30-2007, 07:23 AM -
FAST Throttle Body
By speedkills in forum General HelpReplies: 0Last Post: 01-10-2007, 07:29 PM
