    Senior Member GottaHaveLS1's Avatar
    Connecticut
    1999 Trans Am M6
    Possible electrical problem?
    Sometimes when i start my TA, the trip odometer resets. It doesnt always do this. Anyone know why? Also, when i start the car sometimes, all the needles, such as RPM, fuel and the speedometer all fly up and then come back down. could these things be related? What could be causing this?
    Senior Member
    Jacksonville, FL
    '99 cars will sometimes do this when the battery voltage is low. Check the battery connections/have it load tested. If it's ok then it may need a new gauge cluster. Doesn't hurt anything, just annoying. Here's the GM TSB on it: 99-08-49-009 Trip Odometer Resets to Zero (Exchange/Install Instrument Cluster). TSB doesn't mention the gauge sweep, but usually happens at the same time. Hopefully it's just the battery.
    Connecticut
    1999 Trans Am M6
    Could anything worse happen if i ignore this problem?
    minthill nc
    99 T/A
    mine dose it when the bat is low just get a new bat and see if that helps
    houston
    Navy Blue
    ls1 trans am
    I have a 99 and had the same problem and was getting worried... like the above post its either the battery or a loose terminal connection in the battery.. should solve the problem.
    Roseville, CA
    05 Wrangler
    00 Z28 sold :-(
    wow..this is a oldie
    Junior Member Racefan's Avatar
    Blue
    1999 Trans AM
    Mine did the samething until I replaced the battery.
  1. Electrical Problem
    By Pewter WS-6 in forum Stereo and Electronics
    Last Post: 05-18-2010, 05:27 PM
  2. Electrical Problem NEED HELP!!
    By camarostripes96 in forum Stereo and Electronics
    Last Post: 04-25-2008, 03:55 PM
  3. Help: Electrical Problem
    By tiny47 in forum Stereo and Electronics
    Last Post: 04-19-2008, 11:14 AM
  4. Electrical/charging problem problem
    By jchcomputers in forum General Help
    Last Post: 02-23-2007, 05:59 AM
