Results 1 to 14 of 14
Thread: No start problem: No crank
12-17-2007, 10:52 AM #1Member
- Feb 2007
- FairField, CA
RED 35TH ANIVERSARY PKG- 2002 CAMARO SS 35th LE
Hey dudes I need your help.. I have an '02 camaro and it has about 53,000 miles on it.. Okay so here what happens. In the moring time or after it has been sitting outside for a couple of hours. My car won't start. I doesn't crank or nothing just the lights come on. After playing with the ignition switch (cycling) back and forth it fired up.. I had the starting system test with a handheld tester. It said the battery was okay and the alt and starter are working fine. So now I think its either the ignition switch or a loose connection somewhere. I did a little searching on here and some people had a similar problem.. they said its the ignition switch. But for a car only have 53K I can't imagine it being that.. well post your replay asap.. So I can get this headache over with.
12-17-2007, 11:38 AM #2Cookie Monster
- Apr 2007
- Watertown, New York
Navy Blue Metallic- 2002 Z28
Could be the starter. Sometimes they can get a "dead spot". Next time you go to start it try and tap it with a rubber mallet while someone is trying to turn it over. If I were you, I would just pull the starter and have someone like autozone or whoever to test it before I would pull the colum apart to replace the switch.
12-17-2007, 11:50 AM #3
If it is indeed your ignition switch it's an easy fix. No need to take the column apart,,,,the actually electrical part of the switch should be mounted on top of the column under the dash.
They are also adjustable,,,I would check to make sure it hasn't moved, sometimes an adjustment will cure the problem. Also could be the neutral safety switch as well.
You didn't mention whether a manual or auto. If manual there will be a neutral safety switch on the clutch pedel. Auto should have something either on the column or on the shifter inside the console,,,,would have to research the GM manual to be sure.
I have noticed on my 6 speed car it does the same thing on occassion,,,and if I push a little harder on the clutch pedal the ignition switch suddenly comes to life. Soon it will be time for a neutral safety switch on this car, or a minor adjustment.
Just some things to check.
12-17-2007, 01:22 PM #4Member
- Feb 2007
- FairField, CA
Yeah its a M6... I was thinking about that switch too.. but I'm still not sure.. I also replace the starter relay.. And it still doing the same thing.. I'm gonna replace the ignition relay and try that out.. If it fires up okay for a couple of days then thats the prob.. But I highly doubt that it will be.. I'm still thinking starter or ignition switch or neutral switch.. does anyone have electrical specs for the neutral switch, starter, and ignition switch. Like the volts and ohm its post to have?
12-17-2007, 07:21 PM #5Junior Member
- Jan 2007
- fountain valley california
red- 1965 chevelle 2drht ss
no start
You also might want to see if your security light stays on when you are trying to start it, it may be a vats issue.Your voltage should be normal ignition voltage 9.6 to 12 volts.
12-18-2007, 07:41 AM #6Member
- Feb 2007
- FairField, CA
Yeah I check the sercurity light yesterday.. when I tired to start it and it came on at first when i put the key in, But after a couple of seconds it turn off.. So I know its not VATS.. My sense's is telling me starter all the way now.. So I'm gonna take off my starter and have it tested at autozone or a kargen.. I keep you guys inform on what happens dudes..
12-19-2007, 10:08 PM #7Member
- Feb 2007
- FairField, CA
okay.. so I just change my starter and my problem seem to have went away.. I'll keep you guys inform in the next couple days to make sure the problem doesn't still exist.
12-20-2007, 10:54 PM #8Junior Member
- Jun 2006
- Gainesville Fla
blk- 2002 Z2835th anniv
I had that same problem with my 02z. I put a new ignition switch in, I tried the VATS trick, and I changed out some ignition part at the bottom of the steering column. I got the some problem 600.00 later. Now my car cuts off when it gets ready. I was leaving Orlando,FL a week ago, I got on the Turnpike running 90mph pitch dark meand my baby girl. My car cut off, it just died I had to reset the computer 3 times. We need to complain to Chevrolet.
12-21-2007, 06:23 AM #9
01-22-2008, 02:34 PM #10Member
- Feb 2007
- FairField, CA
it ended up being the starter... its been nearly a month or two since i las wrote on here.. Just keepin you folks updated.. aight.. peace..
02-28-2008, 05:49 PM #11Pontiac Addict
- Mar 2007
- Northern Indiana
Black on black- 2003 Bonneville SSEi S/C
Thats interesting... Im having the same problem, car wont crank but all the lights come on... I think i may try the starter now... Thanks for the info.
08-26-2008, 11:17 AM #12
so if the security light keeps blinking its more than likely to be the vats than anything else?
08-26-2008, 02:51 PM #13
08-28-2008, 03:29 PM #14
hey guy i just tried bypassing the security system with a risistor that matches the one on my key , and it didint work any other options ?
99 Trans Am WS6 will crank over but not start
By REDVENOM in forum General HelpReplies: 12Last Post: 11-08-2013, 03:36 AM -
Help!Ls1 wont start unless i crank it 10 seconds
By Leeroyws6 in forum General HelpReplies: 56Last Post: 10-02-2010, 02:50 PM -
12 volt power No crank no start
By zmg00camaross in forum General HelpReplies: 24Last Post: 04-27-2010, 08:42 AM -
No Start: No Crank
By darwal61 in forum General HelpReplies: 2Last Post: 08-19-2006, 05:39 PM
