Results 1 to 3 of 3
    virginia
    2002 CETA, 97 WS6
    No Start: No Crank
    2002 Trans Am - Car has been garaged with a battery tender. Went out today and put the key in and nothing. You can here the fuel pump and some relays but no starter. Other problems no dome lights, no mirror lights, no power door locks, no running lights. But there are dash lights and headlights.
    Any ideas? Body Control Module?
    If it is the BCM would the battery tender have done it?
    Senior Member
    Jacksonville, FL
    I'd suspect the battery/connections first. Whenever I reconnect the neg on the battery I hear the relays clicking on/off. Check the voltage on a meter for starters, but remember you can have voltage and not enough AMPs to turn the car over. If it's a Delco look real close at the pos terminal to make sure it's not leaking. Hope this helps...hopefully it's just the battery.
    Bragg NC
    Met. Sunset Orange
    01 SS
    Lol yepp keep an eye on that pos delco, it got me
    Like 2001 one said take a look at your battery, Have it tested or grab a multimeter and see whats goin on.
    J
  1. 99 Trans Am WS6 will crank over but not start
    By REDVENOM in forum General Help
    Last Post: 11-08-2013, 03:36 AM
  2. Help!Ls1 wont start unless i crank it 10 seconds
    By Leeroyws6 in forum General Help
    Last Post: 10-02-2010, 02:50 PM
  3. 12 volt power No crank no start
    By zmg00camaross in forum General Help
    Last Post: 04-27-2010, 08:42 AM
  4. No start problem: No crank
    By WARP211 in forum General Help
    Last Post: 08-28-2008, 03:29 PM
