Results 1 to 15 of 15
    Member hmorris7000's Avatar
    Alabama
    BLACK
    02 CAMARO SS a4
    SLP Blackwing factory lid vs aftermarket lid will there be any hp increase?
    I have a factory slp blackwing lid and wanted to know if I got a aftermarket lid such as a mti lid or something like that will i see a h.p. upgrade? After looking at my blackwing and looking at a aftermarket I see that the after market lid hooks straight up to the maf where my blackwing has a little rubber boot that hooks up to the lid then to the maf it starts out flat then forms to the maf where the other lid is the shape of the maf from the beginning of the lid was wonding if this caused the blackwing to flow less and loss h.p.? thanks guys for any help
    in my Trans Am
    2000 Trans Am WS6
    not sure what you mean by " hooks right up to the MAF" there has to be a filter somewhere in there first, Just a bit confused about that. Any pics. Honestly the less turbulance the air has coming in the more hp.. less curves sharp turns, more hp, colder air ,,....more hp. I wouldnt think there would be a big difference between the two hoods if you are using the same filter and intake system. if one "hooks up better" is in with a better seal for ram air, you may see more hp there b/c it pressure charges the system, if i haad pics I could tell you much better. What type of intake sytem are you using, we can go from there.....
    Alabama
    BLACK
    02 CAMARO SS a4
    i was saying that that aftermarket one lid hooks straight to mass air flow sensor with out a boot like on the blackwing lid im post the pic for u to compare pic one with slp lid see how it hooks straight to the m.a.f.\ pic to blackwing see the lil boot from the lid and how it goes from oval to the actual form of the m.a.f.
    Feb 2006
    2002 WS6
    I can't see there being much of differnance if any as the shape of both lids are nearly identicle. And both are made SLP, the black wing lip is manufactures to look and be factory, where as the SLP lip that most are familure with is manufactured to be cheap and look after market.
    Shepherd, Michigan
    blacker than wesleysnipes
    98' trans am
    no you wont see much diff. stick with the blackwing
    Feb 2006
    2002 WS6
    This leads to another question, where would one get the black wing set up? I like it better then an aftermarket lid.
    Bragg NC
    Met. Sunset Orange
    01 SS
    Keep the Blackwing, It flows just as well as the aftermarket lids.
    J
    Ewing, NJ
    1969 Z28 JL8 crossram, #'
    There won't be a difference but the Black Wing lids seem to sell for $300+ and you can get an aftermarket for under $100. So you could make an easy $200+ to use towards other mods!
    Blackwing lid on Ebay
    in my Trans Am
    2000 Trans Am WS6
    I am retarded, i was thinking you were talking about hoods as you can read from my post,...dont ask me why becasue I have no idead except that I am retarded. IMO I would say its not going to make a difference. What may make a diff is if you go with the K&N FIPK system for the trans am. Its proven to add 14.74 hp.....http://www.knfilters.com/search/prod...Prod=57-3022-2
    Shepherd, Michigan
    98' trans am
    K&N and slp are known for overstating gains. keep the blackwing.
    in my Trans Am
    2000 Trans Am WS6
    yeah i agree with the over statement, but with the k & n you have more filter surface area,and the flow is less turbulant...... if your keeping the black wing at least get a flat K&N filter for it.
    in my Trans Am
    2000 Trans Am WS6
    check out the dyno chart on that link I sent
    Member 98CamaroSS's Avatar
    New Jersey.
    Navy Blue
    98-Camaro SS.
    IMO keep the Blackwing. You won't find a better made lid. Seals perfectly also.
    38 of 139 PontiacFan's Avatar
    Kearney, NE
    2001 Pontiac
    That Blackwing is a piece of junk.
    Go buy an aftermarket lid & sell the Blackwing to me, as I need another one
    Wisconsin Rapids, WI
    1999 Z/28 M6
    what did the blackwing come on?
    does it have the fins on the inside of it like the stock factory lid has or is it smooth inside like the slp?
    and finally...what's the big whoop about it?
  1. Aftermarket Fog Lights - Factory Switch
    By bhunter0830 in forum Stereo and Electronics
    Last Post: 05-31-2014, 06:41 AM
  2. WS6 seats, aftermarket or factory?
    By az gt eater in forum Appearance Section
    Last Post: 10-27-2013, 04:56 PM
  3. For Sale: SLP Blackwing Lid, SLP Camaro SS key chain & factory remote.
    By 98CamaroSS in forum Parts For Sale / Trade
    Last Post: 11-13-2010, 12:06 PM
  4. Real world MPG increase from aftermarket
    By Mr. Hyde in forum Almost Anything Goes
    Last Post: 03-05-2009, 03:29 AM
  5. Question: Factory 12 disk with aftermarket deck
    By GNICTRY in forum Stereo and Electronics
    Last Post: 06-12-2008, 01:02 PM
