    Member bhunter0830's Avatar
    Apr 2012
    Fishers (Indianapols), IN
    2009 Pontiac G8 GT
    Aftermarket Fog Lights - Factory Switch
    Does anyone know the schematic for the factory wiring on the 00 t/a? Melted the factory fogs and found replacements. Pulled the factory switch and tried to tie into, but there's several wires I'm not sure of. Any help would be useful. I hate having random switches floating around, would rather use factory to make look cleaner.
    Thanks!
    Jul 2009
    North of the Motorcity
    Custom Swirly Black
    2001 WS6 M6
    I sadly don't have my book any longer, but there should be 4 wires, correct?
    Do you have a continuity tester?
    Feb 2006
    Orange County, NY
    always dirty
    2013 Ram 2014 Caddy ATS
    Is the wiring that went to the fog lights still intact?
    Apr 2012
    2009 Pontiac G8 GT
    Yes, sorry it's been a while. Had some "life" shit going on. 4 wires to the switch and the factory wires are intact.
    2000 Trans Am - Sold
    BBK LT's, ORY, SLP LM2, SLP Cold Air Intake, Wide Band O2, American Racing Torq Thrust 2's, Founders STB, LCA's, LCA Relocation Brackets, Adjustable PHB, BMR Lowering Springs. Deleted AIR & EGR & Tuned By Frost. 1 of 23 MRM with options.
    2009 Pontiac G8 GT Stock
    Feb 2006
    Orange County, NY
    always dirty
    You should be able to wire right to the connector that went to the factory fog lights. Purple is the positive and black is the negative.
    Apr 2012
    2009 Pontiac G8 GT
    Thank you! I am assuming the other two wires go to the relay that makes them flash when the car is locked and unlocked.
    Feb 2006
    Orange County, NY
    always dirty
    Yellow goes to the fog lamp relay. Grey is for the light on the switch.
    Apr 2012
    2009 Pontiac G8 GT
    Perfect, thank you!
  1. WS6 seats, aftermarket or factory?
    By az gt eater in forum Appearance Section
    Last Post: 10-27-2013, 04:56 PM
  2. Question: Factory 12 disk with aftermarket deck
    By GNICTRY in forum Stereo and Electronics
    Last Post: 06-12-2008, 01:02 PM
  3. Replies: 14
    Last Post: 12-07-2007, 08:20 AM
  4. Replies: 2
    Last Post: 05-10-2007, 03:48 PM
  5. Aftermarket WS6 Lights
    By dougcw in forum Appearance Section
    Last Post: 08-04-2006, 06:41 PM
