Thread: Clear Corner Lenses install
11-27-2007, 05:24 AM #1
does anybody have any tips or tricks to making the swap out any easier. Also looking at the clear lense it appears taller then the stock lense, at least what you can see from the front looking at it in the bumper cover. does the lense extend up into the cover about an inch or so???
For a '02 Camaro
11-27-2007, 05:57 AM #2
- Jun 2007
- Lathrop, Missouri
11-27-2007, 07:31 AM #3
Remove the headlight to gain access to the corner lights. You will notice that the bumper covers some of the light so thats why they look shorter. I suggest you put some silicone around the new corner lights so they don't fog up.
2002 Artic White SS 35th Wheels|Full Hotchkis Suspension|Koni SA|Magnaflow CME|SLP lid|www.fquick.com/The_Guz
11-27-2007, 04:50 PM #4
well i got the set from rk sport and the passensger side fit well but the driver side didnt line up with opening for poop, they are sending me a new one to replace it, hopefully it fits alot better
11-27-2007, 04:51 PM #5
where did you all get yours from, anybody got a real close up picture so i compare fitment on mine to, thanks
11-28-2007, 02:25 PM #6
The bumper covers a good portion of the lens man. Take off your headlight lenses. Remove bulbs from everything. Now most people always forget, but there's a bolt that goes through a clip in the center of the corner lens. Take out the bolt and pop off the clip. It took my friends 5hours easy to get theirs in from the bottom, so it's def alot easier to take the headlights off and go in from the top. Hope that helps man.
11-28-2007, 03:08 PM #7
- Jul 2007
- Augusta, Georgia
Bright Red- 99 Z28 M6, 03 Gixxer 1000
Going from the bottom was kicking my a$$ too. Listen to Mike Something. I know from experience. Once the headlights were out, the install of the corners was not hard at all.
11-28-2007, 03:24 PM #8
Ya defintaly take the headlights off to get to the corners. When i took my headlights off to do the whistler mod i looked in and the corners were right there easily too take off if i needed too.
11-28-2007, 06:19 PM #9
I got the headlight out just fine and did the install very easy, but the driver side didnt fit right and they are sending me another one to replace it. the stocker fit perfectly as it should the aftermarket one didnt. if that doesnt fix it maybe i will cut the lenses off and put them on the stocker pieces
how to install clear corner lenses
By TRY ME GT in forum Camaro / SSReplies: 31Last Post: 08-28-2008, 09:08 AM -
Clear Corner Lenses
By sscamaro22 in forum Appearance SectionReplies: 32Last Post: 02-10-2008, 09:52 PM -
Clear lenses/tinted lenses
By patriot1136 in forum Appearance SectionReplies: 4Last Post: 12-24-2007, 12:24 PM -
clear corner lenses and rear
By kebie05 in forum Appearance SectionReplies: 9Last Post: 10-03-2007, 03:39 PM -
Clear Corner Lens Install
By SSwt00SS in forum Appearance SectionReplies: 23Last Post: 09-11-2007, 02:15 PM
