Results 1 to 20 of 32
03-04-2007, 11:54 AM #1Iraq money well spent.
- Mar 2007
- Quantico Virginia
Black on Black- 2000 Camaro SS M6
how to install clear corner lenses
i just purchased a set of front clear corner lenses for my SS. How hard is it to change them out, and how do I go about doing it?
03-04-2007, 12:14 PM #2Just me
- Nov 2006
- Broken Arrow, OK
Easiest way is to pull the headlights out and do it from the top. There are 3 (7mm I believe) screws you have to remove from the turnsignal. It takes some work to get the corner over the bracket that holds the front bumper cover, but just stick with it. Also, be sure not to scuff your front bumper cover, when removing/installing the turnsignals.
03-04-2007, 12:27 PM #3Iraq money well spent.
- Mar 2007
- Quantico Virginia
Thanks for your reply man
03-04-2007, 01:27 PM #4
I took the whole bumper cover off...it made things easier. You will be very happy with the completed project.
03-05-2007, 07:28 AM #5
Removing the headlights is the easiest way. I think there is only one bolt holding them on. The whole housing and everything comes off as one piece. I got confused and thought I had to dissable the headlights to get to the turn signals. This is not the case! Job is very easy and looks great.
03-05-2007, 07:33 AM #6Iraq money well spent.
- Mar 2007
- Quantico Virginia
They look sick man! I cant wait to get mine in. I guess ill go the headlight removal method.
03-18-2007, 05:43 PM #7Iraq money well spent.
- Mar 2007
- Quantico Virginia
I put them on today! I really like the look. I just removed the headlights. you were right, there was only one screw to remove. i could probably change both of them again in 30 minutes. thanks guys
03-18-2007, 11:56 PM #8Member
- Nov 2006
- massachusetts
mystic teal metallic- 1998 Z/28
03-19-2007, 05:08 AM #9
03-19-2007, 12:40 PM #10
03-19-2007, 12:43 PM #11
Thanks Chris!!!!
03-19-2007, 01:17 PM #12Member
- Nov 2006
- massachusetts
03-19-2007, 02:04 PM #13
03-19-2007, 02:15 PM #14Iraq money well spent.
- Mar 2007
- Quantico Virginia
damn guys. i just through out my orange ones. i could have mailed them to mystic so none of you would have had anytime with your cars
03-20-2007, 05:06 PM #15SMKDFRDGuest
Where did you get you clear corners and for how much? Lookin to put some on mine too.
03-20-2007, 05:11 PM #16Iraq money well spent.
- Mar 2007
- Quantico Virginia
afterthoughtsauto. $45.
they are very easy to install. you just open the hood. undo one blot from the back of the headlight assembly, and wiggle the headlamp out. then the corner light is right beneath it. that one has 3 7mm screws to undo. all in all an easy install. if you need pics, i took some.
03-21-2007, 12:41 PM #17
pics would be kinda cool even tho its pretty straight foward
those clears with the grill make that camaro look sick!!!!!
definitly going to be doing this soon
04-26-2007, 02:07 PM #18
who make has the best prices and doing the clear corners does my light still come in orangish color casue i think thats a sig for our cars
04-26-2007, 03:43 PM #19
The signal bulb is yellow, so it will still come on as yellow for the turn signals.
04-26-2007, 04:21 PM #20
and for the day time runnign lights too right?
Clear Corner Lenses
By sscamaro22 in forum Appearance SectionReplies: 32Last Post: 02-10-2008, 09:52 PM -
Clear lenses/tinted lenses
By patriot1136 in forum Appearance SectionReplies: 4Last Post: 12-24-2007, 12:24 PM -
Clear Corner Lenses install
By ChrisV 02 - Z28 in forum Appearance SectionReplies: 8Last Post: 11-28-2007, 06:19 PM -
clear corner lenses and rear
By kebie05 in forum Appearance SectionReplies: 9Last Post: 10-03-2007, 03:39 PM -
Clear Corner Lens Install
By SSwt00SS in forum Appearance SectionReplies: 23Last Post: 09-11-2007, 02:15 PM
