Results 1 to 14 of 14
    Senior Member clg82's Avatar
    Feb 2007
    California
    2000 Trans Am
    Lower control arms.....
    Are lower control arms worth buying? Do you notice a difference, and are they hard to install?
    Install is fairly easy.
    Very much worth it.
    Feb 2007
    California
    2000 Trans Am
    Will you tell a difference?
    Oh yeah.
    Senior Member M-Ten's Avatar
    St. Pete, Florida
    Silver+Black/Black+Silver
    1999 TA M6/03 GSXR 600
    what do they do??
    Jun 2002
    Montreal, CANADA
    triple-black
    2000 CamaroSS convertible
    depending on the LCA, you can either hinder or improve handling.
    Eugenio_SS
    Feb 2007
    California
    2000 Trans Am
    Quote Originally Posted by Eugenio_SS View Post
    huh? now i'm totally confused!
    St. Pete, Florida
    lol
    Jun 2002
    Montreal, CANADA
    triple-black
    among other things, the LCA makes sure the rear axle stays perpendicular to the direction of the car... don't want the axle to do steering... lol
    When doing it's job, bushings will bind... especially polyurethane.
    When that happens, it's not letting it do its job... and you'll lose traction earlier than if you had the stock ones.
    Rod-ends will be better, but you have to make sure you get proper ones... otherwise, they'll just be noisy and clunking noises will occur.
    Feb 2007
    California
    2000 Trans Am
    Are these a good set?
    http://cgi.ebay.com/ebaymotors/ws/eB...192956455&rd=1
    Jun 2002
    Montreal, CANADA
    triple-black
    polyurethane bushings will kill your cornering... drag only.
    The rear of the car will be more tail happy and you'll lose traction earlier, ie, you'd be able to push the car more cornering without losing traction w/ stock setup.
    You decide on your priorities, though.
    Feb 2007
    California
    2000 Trans Am
    Jun 2002
    Montreal, CANADA
    triple-black
    i'd stay away from polyurethane bushings, unless you want a drag-car.
    I'd stay w/ stock ones or go for something like this:
    Member Blue28's Avatar
    Ca.
    Navy Blue
    1999 Camaro Z28
    Hi clg82,
    If you really don't want adj rod ends on both ends, Edelbroch makes a nice one(#5274) that's made with thick .120 wall tubes and poly. on the chassis end,then spherical bearing on the axle end, but there not adjustable if that matters to you.That would be a nice compromise between suspension flex and noise. But there more expensive then the umi or spohn control arms, and I think there nicer.The best prices I found are at:http://www.ajusa.com and http://www.tognottisautoworld.com for 218.00 w/free shipping
    I've been looking at these for a while now since the spherical bearing in my 8yr old global west control arms started to drive me crazy with all the noise they make. Don't get me wrong the suspension flex is way better then stock arms and only a little louder then poly on both ends with good bearings , but once the bearings start going out they get NOISY!
  1. Lower control arms
    By jodmari in forum Suspension and Handling
    Last Post: 07-02-2013, 06:20 PM
  2. Lower control arms
    By johnfin in forum Firebird / WS6
    Last Post: 05-14-2013, 12:50 PM
  3. BMR front LOWER CONTROL ARMS / A-Arms
    By 97ramsst in forum Parts For Sale / Trade
    Last Post: 12-15-2010, 05:59 AM
  4. Lower control arms
    By schurke in forum Suspension and Handling
    Last Post: 12-28-2007, 01:16 PM
  5. FS: NOS 1LE Lower control arms
    By LS1Z28 in forum Parts For Sale / Trade
    Last Post: 12-26-2007, 07:00 AM
