Results 1 to 11 of 11
    Senior Member M-Ten's Avatar
    St. Pete, Florida
    Silver+Black/Black+Silver
    1999 TA M6/03 GSXR 600
    Temp Gauge Sensor??
    The gage that shows temp on the console is not working, it never moves at all. I checked the fuses and it's not that because all the others are working. I checked the codes and it's saying "Temp. Gage Data Out of Range"
    Will replacing the temp sensor in the car fix this? I can buy one for like $20 but I want to make sure that this is the problem before I do that.
    Aug 2000
    Indy
    what car ?, 78 volvo ?
    St. Pete, Florida
    lol ? 99 t/a
    Senior Member
    Jacksonville, FL
    Gauge gets the temp reading from the ECT sensor via the PCM, so replacing it should make it work again - I'd check the sensor connector and wiring first before purchasing one.
    St. Pete, Florida
    yeah the connector looked fine to me, i got a new one for like $17 so i'm gonna hook it up in a little bit and hopefully that will do it...
    St. Pete, Florida
    Quote Originally Posted by 2001NBMZ28 View Post
    I replaced the sensor on the driver side, and it didn't change anything! The guage is still saying that the car is at like 110 degrees.
    Senior Member
    Jacksonville, FL
    Time to look up the description/diagnostics for the code at gearchatter.com
    St. Pete, Florida
    where do i go on that site? never been to it before
    Senior Member
    Jacksonville, FL
    www.gearchatter.com/viewforum35.php Click on the DTC code(s) it's throwing.
    St. Pete, Florida
    oh ok thanks.. yeah it was reading a p0410, p0412, and p0418. I read some where that those codes for GM translate into : "Temp Gage Data Out Of Range" .. which makes sense because my temp gage is not working.
    Do they translate like that or no?
    St. Pete, Florida
    Here's the code it translates to...
    B0566
  1. Want to trade Tranny Temp gauge for Oil pressure gauge.
    By jrbonds in forum Parts Wanted / Trade
    Last Post: 07-29-2011, 08:47 AM
  2. Question: Reading trans temp stock sensor vs aftermarket sensor in pan
    By senicalj4579 in forum Computer & Tuning
    Last Post: 03-29-2011, 07:41 AM
  3. Temp Gauge
    By Bouvers in forum General Help
    Last Post: 08-19-2008, 12:17 PM
  4. Hooking up Oil pressure gauge,and Temp Gauge
    By BirdFlewLS1 in forum General Help
    Last Post: 01-15-2008, 06:15 AM
