Results 1 to 20 of 20
    Member hmorris7000's Avatar
    Alabama
    BLACK
    02 CAMARO SS a4
    longtube headers w/o tune= problems? help please!!
    i wanted to know if i put lt on my car without a tune would i tear something up on my car? any help will be appreciated thanks!!!!
    old timer blue02Z's Avatar
    2002 Z28
    def. not. i ran mine for a year without a tune and no probs. just runs a lil rich
    Shepherd, Michigan
    blacker than wesleysnipes
    98' trans am
    no your fine...it will run real rich..however dont not get a tune..you should get one as soon as possible..or else you run the risk of running rich...
    Senior Member 35thAnniZ28's Avatar
    eating bulldog
    son of biscuit
    you could if your not careful...while your unbolting the manifolds off...your going to have to unbolt the starter and air...while your down their you might as well install the prothane motor mount bushings,many people complain about the header rubbing against the frame...
    Alabama
    BLACK
    02 CAMARO SS a4
    what does running rich mean or do? thanks guys your life savers how much do u gain with the lt's w/o tune? with tune? i want a tune but there are no tuners in alabama im probably gonna have to go to ga or fl to get a tune which sucks but wanted to know if i would be ok for a while without a tune
    2002 Z28
    Quote Originally Posted by 35thAnniZ28 View Post
    you dont have to unbolt your starter and air system
    Quote Originally Posted by hmorris7000 View Post
    running rich just means burning more fuel. maybe 20 hp with no tune i would say. like i said, i ran mine for a year w/ a stock tune
    2002 Z28 M6, Suncoast Creations ram air, port/polish TB w/ bypass and bumpstop, heater hose mod, stainless steel long tubes, ORY w/ dual cutouts, Magnaflow, BMR SFC, UMI Torque Arm, LS7 clutch w/ drill mod, Pro 5.0 w/ Lous short stick, MSD wires, 4.10s, good maintenancehttp://www.fquick.com/blue02z
    Member ApexVIII's Avatar
    Modesto, CA
    1998 Camaro Z28
    yea no problems here mine is still untuned. you will pick up some more hp and it will run a little better. but i just run a little rich.
    M6, Lid, Ported and Polished Throttle Body (By Me!), LT, Custom Catted Y, Electric Cutout, PHB, LCA13.21@108 with a 2.3 60'
    eating bulldog
    son of biscuit
    [QUOTE=blue02Z;1137839]you dont have to unbolt your starter and air system
    well..made shit a whole alot easier....i meant air hoses
    Slow SS
    P-Cola
    2002 Chevy Camaro
    takes all of 30 sec to pull the starter so i reccommend it. also, before my tune with lt's I got 75 miles to the TANK, get a tune, I am back up to normal milage after, and the tuner bought me 20 hp
    2002 Z28
    thats cool, mine went in so smooth i did not need it
    Quote Originally Posted by dlbrando View Post
    holy sh!t!!!!!!!!!!!! were you driving with the pedal on the floor. before my tune i drove from here to yellowstone and averaged 32mpg, the whole trip! no joke. i really dont see how you only got 75 miles to the tank, that amounts to like 4.5 mpg
    2002 Formula Firehawk 96z28's Avatar
    San Diego CA
    yeah thats kind of insane. you sure it was 75 to the tank?
    Slow SS
    P-Cola
    2002 Chevy Camaro
    I am not sure what happened, but I definatly got around 75 to 80 on a tank, certainly no more than 100. I got it tuned after a tank and a half. And no, it was normal city driving. I drive stop and go to school work and my apt most everyday the only highway I get is when I roll around the beltline to the mall.
    Elk Grove C.A
    2002 ss camaro 35th
    i just put some long tube kooks headers an they ran really rich..i suggest a tune to make your car feal way better and preform better
    Member Blue_98_ws6's Avatar
    georgia
    blue
    1998 trans am ws6
    i bought my car with hooker lts and ypipe and it definitly runs rich i dont think the guy ever had it tuned. how much do they cost? and where would i go to get one done?
    Built A4 with B&M Transpak shift kit, Hooker Lt's, 0RY, 4in cutout, Debaffled, K&N, SLP Lid, Bellows, p+p+descreened MAF,TB bypass, 180 degree Theromostat, AC removed, RP Trans fluid, oil, MSD 8.5 wires, Autolite Xtreme perf plugs, Nitto DR
    Coming soon SFC, 373 gears, 96mm intake/96mm TB, Tune
    Slow SS
    P-Cola
    2002 Chevy Camaro
    call around to local performance shops, average tune is between 200 to 300 bucks, it depends on what they can do. Mine was 250.
    Member rel3rd's Avatar
    Baltimore, MD.
    Bright Red
    2000 Pontiac Trans Am WS6
    My car must be an oddball, or I am reading this RICH after header swap thing wrong.
    After longtubes and ORY...
    At IDLE and light CRUISE RPM it was a little RICH out of the tailpipes because car is actually LEAN (due to headers) and pcm adds fuel to compensate.
    WOT was definitely LEAN...as it should have been, since exhaust was opened up and a/f ratio is ignored by O2 sensors at WOT.
    Idle and light throttle cruise were leaned out during tune, and at WOT a good bit of fuel was added to make best all around power, and to get WOT a/f ratio in check. Found pretty much 20rwhp everywhere, slightly more at peaks. (Mustang Dyno, FWIW)
    2019 Silverado LT Z71 5.3, 8L90E
    2000 Pontiac Trans Am WS6 6.0, 4L80E, 9" rear, TURBO...
    9.32@147
    2002 Z28
    your car is crazy then dude, my 74 built c10 with a built 350 pushing around 400 at the crank and a slippin th400 and 3.73's on the hiway gets like 12mpg. i feel sorry for you
    Slow SS
    P-Cola
    2002 Chevy Camaro
    Quote Originally Posted by blue02Z View Post
    well it is better now... tune fixed all of that
    Ewing, NJ
    1969 Z28 JL8 crossram, #'
    I did the lid, ported TB, free airbox mod and EGR tube mod and my car was adding fuel big time(LT trims were around 12.5% on the highway). I just did the longtube headers and the LT trims are down a little bit but still adding 10-12% on the highway. You guys who say they were running rich might be backwards on that thinking. More airflow with stock computer will definitely be leaner than stock. I think the ORY with no cats makes the exhaust smell and look different, but that's not running rich, it's running dirty. The 75 miles to a tank sounds like you had a dead O2 sensor and the car was running on SD or limp mode.
    Slow SS
    P-Cola
    2002 Chevy Camaro
    had 1 bad o2, but the problem persisted after the fix. the tune fixed all of it and restored my milage. Most of us can say we were running rich for sure because we had the A/F ratio checked and it was off for sure
  1. Question: Longtube headers/
    By 98maro in forum External Engine
    Last Post: 07-11-2010, 09:09 AM
  2. Question: Longtube headers or short headers?
    By 98maro in forum General Help
    Last Post: 03-01-2010, 05:25 AM
  3. longtube headers w/o tune= promblems? help please!!
    By hmorris7000 in forum External Engine
    Last Post: 12-02-2007, 07:40 AM
  4. SLP Longtube Headers
    By weaponx13 in forum Parts Review
    Last Post: 10-05-2007, 05:37 PM
  5. Longtube Headers
    By morocotopo in forum External Engine
    Last Post: 10-20-2005, 09:41 PM
