Results 1 to 14 of 14
    Member 98_ls1maro's Avatar
    ?? about torque converters
    My car is mostly stock A4 , save for a slp lid and cutout. On my street tires I I ran a best of [email protected] with a 2.095 60 foot. Then I bought Nitto drags , and now I can even get in the 2.0's 60foot. Mostly in the 2.1-2.2's. Now I usually run 8.85's@82. The funny thing is that I am not even spinning. On the launch it takes off hard but then inmediately bogs or seems like it grabs too much. Then SLOWLY the rpms start climbing. It seems like I NEED to take off at a higher rpm. I was thinking of a Yank 3600, will this be too much for the street? Has anybody had this problem before with their A4?
    Shepherd, Michigan
    blacker than wesleysnipes
    98' trans am
    3600 is fine...just remember...if your running a stock 10 bolt..with DRs...say good bye...also the bogging might be to your suspension..if everything isnt set up right then you dont get good weight and power transfer.
    At this moment I have stock suspension. Does removing the front swaybar help? What other suspension mods can I do to help it even more. Is DR's that bad with an Automatic?
    Dec 2002
    n/w chicago
    2000 nhra edition formula
    depends what DRs. unless they are slicks, hell be fine.
    a few bolt ons, 379 rwhp
    11.96 @113.25
    Dec 2002
    n/w chicago
    Quote Originally Posted by 98_ls1maro View Post
    just dont use a slick style dr and you will be fine.
    ive been running DRs for 4+ years and all is good
    FAQ2 99DROPTOPZ's Avatar
    Chicago
    1999 Chevy Camaro Convert
    Quote Originally Posted by nhraformula View Post
    What dr's are you using???
    99 Z28 VERT A4 MODS: B&M transcooler, LS6 Intake, Pacesetter LT, ORY pipe, Flowmaster AT cat-back, SLP LID, UMI SFC, Hotchkis RLCA'S & STB. Tuned by Speed inc.
    Cedar Rpaids,IA
    1998 Camaro SS
    Yes removing or unhooking the front sway bar might help, but I don't recommend this on a street driven car.
    Parts that will help:
    1 If you don’t want to get torque dents on your car get some subframe connectors. Also this makes the car much stiffer so you don’t loose any power to body flex.
    2 Relocation brackets
    3 New torque arm
    4 Set of adjustable shocks
    1998 Camaro SS Hard Coupe Bright Red #1593
    Mods: Lots!!, still my daily driver except for winter
    383rwhp 370rwft/lbs
    1979 Corvette
    Mods Lots!!, weekend cruiser
    325rwhp and 320rwft/lbs
    2007 Dodge Ram 1500 4x4 (Yes its got a HEMI)
    Mods: Catback, BFI CAI, Winter daily driver
    Dec 2002
    n/w chicago
    Quote Originally Posted by 99DROPTOPZ View Post
    BFG
    I am using Nittos DR(245/50/16). As of now they hook pretty good. TOO good I would say. What are some good adjustable shocks?? I am thinking of doing rear V6 springs also, and 3.73 gears.
    d
    2002 z28
    i heard this before how DRs slowed them down bc of bogging and not spining and rpms. there is a thread around here but couldnt find it. not sure if its true but... but a nice TC wont hurt
    Yeah it sucks man, I thought I was going to improve my times. I guess I'll have to go back to street tires until I get my converter.
    calif.
    More power-- and or a stall converter--I have BFG DR's and they are great & a 2600 stall for my DD--lower gears would help too---Do you know your rear dif. ratio ?
    I have 3.23's
    calif.
    I have 3.23's
    That would explain the bog !!---stock power-- with a stock converter and 3.23's---3 things that are working against a quick leave-
  1. couple ?s on torque converters
    By qwik219d9 in forum Automatic Transmission
    Last Post: 02-04-2010, 05:14 PM
  2. Torque Converters
    By ls1speedster in forum Automatic Transmission
    Last Post: 05-07-2007, 07:01 AM
  3. TCI Torque converters
    By Fire Chicken of Doom in forum Automatic Transmission
    Last Post: 10-21-2006, 08:37 PM
