Results 1 to 13 of 13
    Member qwik219d9's Avatar
    Sep 2008
    Atlanta, GA,Ft.Walton Bch,FL
    Blog Entries
    1
    99 ws6
    couple ?s on torque converters
    I've read on the net that a out of balance TC can not only ruin a transmission but also the engine, ?1.is this true or false? I'm assumming it's true.
    ?2.can a transmission shop check for prefect balance of a TC? if yes do they balance the TC?
    I'm assumming it's like balanceing a crank either adding wieght or removing wieght.
    Thanks
    cam-LTs-FAST78-Susp.-Rims
    Shepherd, Michigan
    blacker than wesleysnipes
    98' trans am
    we talking stock or aftermarket ?
    yes i can see a out of balance TC causing increase wear.
    for your other questions i dont know.
    Sep 2008
    Blog Entries
    1
    99 ws6
    yank
    yes after market. I've picked out the Yank stealth 2600.
    http://www.converter.cc/converters/street/GM/5/
    I know it's for a truck but have read on the net folks use them on LS1 cars also.
    Shepherd, Michigan
    98' trans am
    why a 2600?
    Shepherd, Michigan
    98' trans am
    i am getting ready to order my yank and i am going ss4000
    Sep 2008
    Blog Entries
    1
    99 ws6
    2600tc
    I don't like a loose TC. this is a DD car.
    2600 is a perfect fit for the duration of my mild cam and rear end gears.
    I'm with shady.....in the long term you'll most likely wish you would've went considerably higher. I run a 3500 in mine and it could easily be daily driven. I *think* yank gives you a free re-stall maybe. Try it out and if you want bigger you can always get it re-stalled. What's the numbers on your cam and what gears?
    Poway, Ca
    SOM
    2001 Z28 (Sara)
    I have a Y3000 coupled to 3.73's, and if I had to do it all over again, I would go with a 3600 stall, do not waste your money on anything below a 3k stall.
    Yank makes a great unit.
    SteveC
    Sep 2008
    Blog Entries
    1
    99 ws6
    cam details
    details on cam w/3.23 gears
    DUR @ .004" 278*/ 286*
    DUR @ .050" 216*/ 224*
    LIFT .551/.551
    OVERLAP 53*
    LSA 115*
    "THE BOSS"
    STREET / STRIP CAM / AUTOCROSS
    POWER RANGE 2000 TO 6200
    TUNING & STALL CONVERTER DESIRED
    PERFECT FOR SUPERCHARGERS
    POWERFUL CHOPPY IDLE
    You will wished you had gone bigger than 2600.
    Shepherd, Michigan
    98' trans am
    off topic..but love the avatar pres.
    Thanks Shady, coming soon
    Arizona
    Quote Originally Posted by qwik219d9 View Post
    LIFT .551/.551
    OVERLAP 53*
    LSA 115*
    "THE BOSS"
    That looks like a "Vinci" camshaft. Pretty mild on duration and lobe sep. Not sure what their idea of "powerfull choppy idle" is, because I run one of their camshafts very similar to those specs in my wifes car, (on a 112),,and I have the thing idling as smooth as a baby's butt at 700 rpm.
    In any event, I'd go higher on the converter as others have mentioned. I have a 3400 in mine with 3.23's and it's easily a daily driver.
    If I had more rear gear, I'd bump the stall even higher. Especially since more rear gear tends to tighten the feel of the converter.
  1. ?? about torque converters
    By 98_ls1maro in forum Automatic Transmission
    Last Post: 11-24-2007, 06:24 PM
  2. Torque Converters
    By ls1speedster in forum Automatic Transmission
    Last Post: 05-07-2007, 07:01 AM
  3. TCI Torque converters
    By Fire Chicken of Doom in forum Automatic Transmission
    Last Post: 10-21-2006, 08:37 PM
  4. Yank Torque Converters
    By SteveC in forum Automatic Transmission
    Last Post: 09-15-2005, 06:53 AM
