11-15-2007, 05:13 AM #1Member
- Woodbridge, VA
Navy Blue Metalic- 1999 Z28 Convertible
Steering Wheel Alignment Question
I just bought a 2001 Plymouth Neon for my daughter (she just got her license) and I just noticed that the steering wheel is turned a little to the left when it is going straight. It does not pull (you can let go of the wheel on a straight away and stays perfectly straight), but the wheel is just a little to the left of center. It doesn't seem to cause a problem and she'll never notice, but it bothers me.
Does anyone know what causes this, and how it can be fixed? Also, is it an indication of a larger problem?
11-15-2007, 09:07 AM #2
The fix is getting an alignment.
The cause is the last alignment the steering wheel was not centered when it was done.
Usually it is a sign of previous damage/repair of some kind.
11-16-2007, 05:44 PM #3
they just didn't get the steering wheel centered when they did the alignment last time.
doesn't necessarily mean there was damage. could have been a repair on the steering parts (tie rods rack and pinion), or just routine maintenence.Cold Air Intake, Muffler Delete, Vinci High Performance Dual Valve Springs, Hardened Pushrods, Yella Terra 1.85 Rockers, Some Hydropdipped Stuff, Strut Tower Brace, Some SS Badges, boost/vacuum gauge, fuel pressure gauge, some checkered stripes, drilled/slotted rotors, ZL1addons Stealth wickerbill, Ruxifey LED side markers
11-16-2007, 05:55 PM #4
The wheel can be straightened with adjustments..you should have the alignment checked though if the toe is off it wont pull it will just eat tires.If they check/ set the toe they can algin the wheel at the same time.
Steering wheel not straight after alignment
By Blue2KTA in forum General HelpReplies: 9Last Post: 05-12-2013, 08:07 AM -
Wheel Alignment Guide - DIY Alignment
By Ed Blown Vert in forum Almost Anything GoesReplies: 5Last Post: 08-06-2009, 03:30 PM -
Question: Alignment without wheel lip
By Wesman in forum Suspension and HandlingReplies: 13Last Post: 05-31-2009, 06:04 PM -
Steering wheel question?
By 99WS6RAMAIR in forum Firebird / WS6Replies: 3Last Post: 05-03-2008, 07:42 AM -
Steering wheel control question
By 94TA25thANNIVERSARY in forum Stereo and ElectronicsReplies: 3Last Post: 04-17-2007, 10:22 AM
