Results 1 to 10 of 10
Thread: Coolant Boiling Over!
11-13-2007, 11:55 AM #1TOPLS1
- Sep 2007
- Canada
White- 2000 Trans am Convertible
Hey all, I've been troubleshooting a problem i've had with my car since i got it and i really need some help! The coolant will boil over when im just cruising around town for a while, however only when the A/C is off. I know the fans come on with the a/c to cool the condesor but the motor isn't too hot. The hottest i've seen it might be 210-215 at the most. HELP!
11-13-2007, 12:25 PM #2
drain the radiator...put knew in..
there is prolly to much water in the coolant..lettin it boil at 212 or just over 212..
mix a new blend of coolant and stick in there....50/50 or so..
i see ur from canada so i would mix new appropraite to the temps..dont want it to freeze
11-13-2007, 03:14 PM #3
one of your fans should operate without the AC on but when the temp hits a predetermined point. It sounds like this fan is not coming on possibly because the fan motor is bad or maybe the relay to the fan has crapped out. Try running a hot wire directly to the fan to see if it still works then go fromm there.
11-13-2007, 03:53 PM #4
try a new radiator cap or have yours tested
11-14-2007, 04:03 AM #5TOPLS1
- Sep 2007
- Canada
Good Suggestions guys, but i've tried all that!
11-14-2007, 04:55 AM #6
11-14-2007, 05:13 AM #711 Second Club 11.34
- Aug 2006
- Streetsboro, Ohio
Red- 1998 Firebird Trans AM
Do you know if the previous owner ever had the car tuned?
are you able to unplug the wire connectors to each fan and test each fan motor to make sure they are both operational?
Have you puilled the therostat to make sure it is the proper one for the car and that it has not been modified?
11-14-2007, 06:59 AM #8TOPLS1
- Sep 2007
- Canada
I know the previous owner didn't have a tune, Both fans do work, i've tried them myself. Come to think of it; i didn't try a new radcap, i'll grab one after work and give it a shot, the car is going into storage anyway on friday,boy is my face is gonna be red if it works.
11-14-2007, 03:03 PM #9
haha...
reply after u get in on...and normal temp
11-14-2007, 10:22 PM #10
Help: Boiling sound at radiator cap
By Blue2KTA in forum General HelpReplies: 10Last Post: 07-31-2012, 06:02 AM -
Boiling point of water/anti freeze
By redls1 in forum External EngineReplies: 3Last Post: 08-11-2010, 02:07 PM -
Something that may get your blood boiling..
By zggill04 in forum Political / Debate ForumReplies: 79Last Post: 08-31-2007, 07:22 AM -
-40 degree weather, pot of boiling water. vid
By Modulistic in forum Almost Anything GoesReplies: 10Last Post: 03-06-2006, 10:31 AM -
ls6 intake coolant plugs or extra front coolant pipe?
By mikes ss in forum External EngineReplies: 3Last Post: 12-03-2005, 04:13 PM
