    Senior Member
    TN
    2016 Dodge Challenger
    Boiling point of water/anti freeze
    Ive read so many opinions Im not sure what to think. I thought water had a higher boiling point and anti freeze was just an anti corrosive and not freeze when it gets cold. I was then told it just has better heat transfer. So what is the opinion here, should it be a 50/50 mix or more distilled water, what about water wetter or similar product and a higher psi radiator cap?
    MOTOR CITY MARO' SSTODD's Avatar
    LIVONIA,MICHIGAN
    PEWTER
    2000 CAMARO SS #3821
    Water boils at 212F, but pressurizing the sealed cooling system raises the boiling point and along with the coolant mix is what get the boiling point even higher I believe.
    Nov 2009
    Norfolk, Nebraska
    2002 Camaro Z28
    Quote Originally Posted by SSTODD View Post
    Yeah that is correct. I wanna say that every 1 psi raises the boiling point 2-3 degrees. So with a 15-16psi cap the boiling point of the 50/50 mix is around 260 or so.
    I wouldn't run a higher psi cap. If your cooling system is working properly the motor shouldn't get hotter than 200-230 anyway.
    Junkyard bought and "refurbished" 2002 Camaro Z28 - Pacetter Race LT's, TS&P ORY, Frost tune, Magnaflow, Ported TB, SLP Lid, Circle D 3000, 3.73's, SFC's.
    2009 Silverado Z71 - Magnaflow
    2008 Impala LTZ - Wife didn't want the V8 SS!
    Bragg NC
    Met. Sunset Orange
    01 SS
    SSTodd is correct, also stay away from water wetter and all that Garbage. Stick with a 50/50 mix and you should be good to go.
    J
  1. anti freeze question
    By 2-bowties&abird in forum Internal Engine
    Last Post: 04-10-2016, 06:55 PM
  2. anti-freeze
    By edrvsqz1980 in forum Firebird / WS6
    Last Post: 10-04-2010, 08:28 AM
  3. Anti-freeze?
    By RPE_2KTRANS in forum Internal Engine
    Last Post: 10-09-2009, 10:22 AM
  4. Question: anti-freeze
    By plumpkibbles in forum External Engine
    Last Post: 09-28-2009, 04:32 PM
  5. Anti-freeze
    By wnmech in forum Internal Engine
    Last Post: 11-27-2006, 06:11 PM
