Thread: lt5 conversion
11-13-2007, 04:20 AM #1Junior Member
- Oct 2007
- lexington,sc
lt5 conversion
when you build a lt1 is the only difference in the conversion to a lt5 the heads and the intake?? what else is needed for the conversion
11-13-2007, 04:35 AM #2Member
- Jan 2006
- Harrisburg
Black- 2000 TA
I think your thinking of the LT4 but I could be wrong.
11-13-2007, 05:21 AM #3Junior Member
- Oct 2007
- lexington,sc
ya the lt4 is just the top end but the lt5 is a dohc version of the lt. it is basically the bad ass motor and back in 93 was makin 425hp from the factory. lotus built it.
11-13-2007, 08:00 AM #4
Parts for an LT5 are very hard to find. Vettes with the LT5 are also hard to find.
But there is so much stuff that has to be changed to convert from a pushrod motor to DOHC, I don't think it would be worth the work (if its even possible with the same block).
11-13-2007, 09:12 AM #5
"Converting" an LT1 motor to an LT5 is impossible - totally different block...and everything else. I'm sure your thinking of the LT4. In that case, GM Performance Parts offers the LT4 heads and HOT cam, but for the intake manifold, you will have to venture over to Edelbrock for their piece, as you cannot get the original intake manifold anymore
11-13-2007, 11:48 AM #6
Adding to what I posted in your earlier thread... The LT5 is a completely different motor. You're probably going to pay around 10,000$ just to get an LT5 motor (used)... So by the time you got done getting a motor and completely building it, you're probably looking at 20-25K$, not including whatever it will cost just to get the motor in the car (potential chassis and frame modifications). And it was designed by Lotus, built by Mercury Marine.
IN lbs to FT lBS Conversion
By SMWS6TA in forum General HelpReplies: 4Last Post: 09-24-2010, 02:28 PM -
Ram Air conversion?
By UKXK189 in forum Firebird / WS6Replies: 13Last Post: 06-28-2007, 09:40 AM -
Ls1 vs Lt4 conversion
By bandit-00 in forum Firebird / WS6Replies: 14Last Post: 10-24-2006, 07:26 PM -
FS: T56 conversion for LS1
By 1badchicken in forum Parts For Sale / TradeReplies: 1Last Post: 10-24-2006, 01:30 PM -
Conversion to Ram Air
By 2001bird in forum External EngineReplies: 0Last Post: 10-19-2006, 08:58 PM
