Thread: IN lbs to FT lBS Conversion
09-24-2010, 01:02 PM #1Spaz is My Mentor
I can't find an inch lb torque wrench anywhere. From my understanding you can convert it to ft lbs by dividing the inch lbs number by 12. This gives you your ft lbs torque number. E.g.
44 IN LBS /12 = 3.6 FT LBS
89 IN LBS /12 = 7.4 FT LBS
Am I wrong in this method? Is there a reason not to try?
09-24-2010, 02:00 PM #2
You are correct. Just divide by 12 to convert inch pounds to foot pounds.
09-24-2010, 02:08 PM #3Exalted Cyclops
- Feb 2007
- San Diego, CA
12 in-lbs = 1 ft-lb so yes you are correct.
If a fastener calls for in-lbs though you'd be better off using the appropriate tool. Most ft-lb torque wrenches don't go below a certain threshold and are highly inaccurate below it.
FWIW, my ft-lb torque wrench doesn't even register below 25 ft-lbs.
09-24-2010, 02:10 PM #4
09-24-2010, 02:28 PM #5
damn plastic intakes. i didnt think the ft lb torques were accurate to that degree and had to borrow a friends to finish the ls6 intake swap.
Ram Air conversion?
By UKXK189 in forum Firebird / WS6Replies: 13Last Post: 06-28-2007, 09:40 AM -
Ls1 vs Lt4 conversion
By bandit-00 in forum Firebird / WS6Replies: 14Last Post: 10-24-2006, 07:26 PM -
FS: T56 conversion for LS1
By 1badchicken in forum Parts For Sale / TradeReplies: 1Last Post: 10-24-2006, 01:30 PM -
Conversion to Ram Air
By 2001bird in forum External EngineReplies: 0Last Post: 10-19-2006, 08:58 PM -
97 GMC LS1 Conversion
By Nitrous in forum GM TrucksReplies: 12Last Post: 08-28-2006, 10:40 AM
