Results 1 to 2 of 2
11-11-2007, 10:13 AM #1Member
- china
How do i wire two seperate front tweeters with no factory wiring or wiring from deck?
Ive got a truck that has two empty spots on the dash for some small speakers but cant seem to find anything that suggests it is pre-wired for them. I checked my aftermarket deck and it just has the wires for the fronts -+ and rears -+ speakers and an rca for subs.
How would i go about wiring these up, im lost.
thanks
11-16-2007, 09:41 AM #2Junior Member
- Oct 2007
- Surprise
Silver- 2005 Silverado 5.3L
thanks
Most aftermarket stereos only have front and rear speakers connections. You could splice off the front speakers to power the dash. However, I wouldn't even go that route. If you have good enough front and rear speakers then you shouldn't need another set. If they aren't loud enough hook them up to an amp. Make sure the you math up the rms watts. Make sure you get component speakers. Screw the 2-way and 3-way crap.
Front wiring harness
By !!!FAST!!! in forum General HelpReplies: 1Last Post: 08-29-2009, 08:00 AM -
Wiring amp to factory monsoon
By gfeller2006 in forum Stereo and ElectronicsReplies: 4Last Post: 09-26-2008, 02:38 PM -
Wiring new deck
By Mike510 in forum Stereo and ElectronicsReplies: 0Last Post: 05-15-2008, 07:07 PM -
Wiring Diagram for Fly by Wire Motor
By MUD000 in forum General HelpReplies: 3Last Post: 06-17-2007, 12:16 PM -
--HELP-- wiring system (passing wire from inside into door)
By Eugenio_SS in forum Stereo and ElectronicsReplies: 5Last Post: 05-14-2006, 06:54 PM
