    Jun 2002
    Montreal, CANADA
    triple-black
    2000 CamaroSS convertible
    --HELP-- wiring system (passing wire from inside into door)
    I've seached with no results
    in the midst of finalising my stereo install... tests are good, and want to pass the wires from the splitters to the front speakers and tweaters.
    That means I have to pass wires through the little wire gourmet that goes to the door.
    Access seems like hell.
    Anyone done it ?
    Any pointers ?
    Especially from the inside of the car area, close to the fuse box... how can i pass wires from inside the car to the door ?
    Thanks for help
    Eugenio_SS
    Rock-n-Roller White Rascal's Avatar
    OHIO Go Buckeyes!
    '07 Trailblazer LT
    I use a wire clothes hanger with the wires taped to the end. I start by feeding it in thru the door into the rubber boot. I use my free hand to help guide the hanger thru the boot. Once it's thru the boot and into the kick panel area the rest is easy.
    The White Rascal SOLD
    Crank up the drums, crank up the bass,
    Crank up my Les Paul in your face!
    Compulsive F bomb dropper sgt0704's Avatar
    yuma arizona
    1998 Z28
    Quote Originally Posted by White Rascal
    Jun 2002
    Montreal, CANADA
    triple-black
    i'll try it from the door towards the inside, hoping i can feel it on the inside and play with it.
    Thanks
    Feb 2006
    Marietta GA
    Mystic Teal Metallic 79U
    1998 Pontiac Trans Am
    That's the way I did it but I happened to have an electricians fish tape. Same thing as a coat hanger. Its is a PIA though!! Especially on the drivers side cause the harness is a little larger going through there as I recall. Use quality cable so you don't have to do it again ever.
    Member mikeaford's Avatar
    Fredericksburg Va
    01 Trans Am
    agree I have a home flat wire puller I spooled out and fed through there wrapped the wire in tape and pulled it back through agree - this is a PITA or lower back...
  1. Help! Door speaker neg/pos wire color?
    By slimjim1284 in forum Stereo and Electronics
    Last Post: 03-12-2011, 05:08 PM
  2. Door wiring and door repair????
    By Piranhaz in forum Firebird / WS6
    Last Post: 09-17-2009, 05:56 PM
  3. Replies: 1
    Last Post: 11-16-2007, 09:41 AM
  4. braided copper wire INSIDE the alternator? Help
    By sic2001 in forum General Help
    Last Post: 08-19-2007, 08:12 AM
  5. Wiring Diagram for Fly by Wire Motor
    By MUD000 in forum General Help
    Last Post: 06-17-2007, 12:16 PM
