Results 1 to 17 of 17
    Junior Member DubisSix's Avatar
    Cali
    Blue
    2002 Trans-Am
    Stuck in GEAR...
    Some crazy sh#ts been happening to my car... Like 2 dayz ago i tried shifting into 5 like normal and it made a crazy noise like if i was grinding my gears even with the cluch in.. and today it did it again but not just that, my gear got stuck in 5th then i pulled it out and now the whole thing feels hard to move..
    so i cant really shift into anything (even in neutral).. im hopeing it will be loss of sum trany oil or sumthing like that.. IF ANY1 HAS EVER HAD THIS PROBLEM.. I COULD USE SOME HELP. THANX EVERY1
    Laurel, Maryland
    2000 Grand Prix GTP
    2000 Trans Am WS6 M6
    Bad Synchro?
    I think I spelled that wrong, but whatever :P
    Cali
    Blue
    2002 Trans-Am
    will sum1 else try at this????
    oppinions??????
    oklahoma
    98 Trans Am Ws6
    I bet its the synchro
    EDIT
    Maybe not doesnt the synchros only effect certian gears not all of them if one goes bad?
    Member Stricken1's Avatar
    Florida
    2001 Trans Am WS6
    Your slave or master cyl may be leaking. Check the fluid level and look under the car for any fluid leaking.
    Rice Killa JwMonE99's Avatar
    Aug 2006
    Myrtle Beach
    Black With T-Tops
    96 Z28 M6
    I am pretty sure its the clutch cable, there are fingers on the actual clutch and when you push on the clutch cable and they dont open all the way it makes it really hard to get into gears and also casues a grinding noise becasue it doesnt release the clutch all the way.
    Do you have an adjustible clutch cable?
    Lost in Texas
    Custom Slate Blue
    99 B4C
    Red face
    Quote Originally Posted by JwMonE99 View Post
    Uhhh, clutch cable?
    Florida
    2001 Trans Am WS6
    Hydrolic clutch no cable.
    Aug 2006
    Myrtle Beach
    Black With T-Tops
    96 Z28 M6
    Oh I am sorry, I just been working on a bunch of mustangs lately so I am still have clutch cables in my mind.
    Cali
    Blue
    2002 Trans-Am
    So if it were to be the cable or anyting like that.. is it costly??
    whatever it is.. it seems expensive to fix.
    could this cable or anything related really be messing up my gears this bad??
    i just cant get my gear stick to move.. i cant even move it side to side in neutral..
    Aug 2006
    Myrtle Beach
    Black With T-Tops
    96 Z28 M6
    Umm, if there was a cable then no becasue they are usually around the $80 range plus 2 hours of frustraions. But i am probably wrong about it being the clutch cable...
    Orig Regist: 9/98
    NE Indiana
    1998 Trans Am WS6 'Vert
    That would be afirmative. No cables in a 4th-gen f-body clutch. A leaky hydraulic clutch system could cause the clutch to not fully release when the pedal is pushed to the floor and result in grinding between gears and make it difficult to pull out of gear while the car is in motion. However...........
    Quote Originally Posted by DubisSix
    This sounds like something more serious internal to the tranny. Start w/ checking the fluid and shifter. If the fluid is OK and the shifter moves freely when removed from the trans, then you probably need to get it looked at by a trans shop.
    Johnny B - '98 "Triple Black" WS6 Convert, M6, All Options, ASC #3030 (1 of 50)
    KBDDSFC, DGM C/F Tonneau, MTI C/F Lid, K&N, HPP-III, 160 T-stat, Pro 5.0
    Link to Firebird Production Breakdowns
    TOPLS1
    2000 Trans am Convertible
    Shift Fork perhaps?
    Member sirenformula350's Avatar
    Chicago
    I have this problem also. It happens to me in third and fifth. When I start to go into gear it'll grind. I was told it could be the synchros. Mine isn't hard to move or anything though. Hope it helps!
    I am going to keep driving mine till its happens all the time but until then I'll deal with the occasional grinding. Tranny rebuilds are expensive
    Junior Member 7901 ws6's Avatar
    NW burbs of Chicago
    2001 Trans Am WS6
    I had the same problem with 5th only. It got worse and worse over time. Fix was to have Tranny rebuilt..
    Cali
    Blue
    2002 Trans-Am
    thanks every 1..
    i took it to my mechanic and i guess im gonna need my trAnny rebuilt. sux
    I heard it might be better just to swap then rebuilt.. not much more.
    Any1 agree??
    Member NJ2002WS.6's Avatar
    New Jersey
    Blog Entries
    1
    Metallic Pewter
    2002 Trans Am WS.6
    This same problem happened to me a month ago. It wasn't a tranny though. My clutch was sticking to the floor and the car would not go in gear. I look in my resovoir and saw that it was bone dry. I took it to my mechanic and it turned out that I had a crack in the slave cylinder. To get to it he had to drop the tranny. While he was under there he noticed that my clutch was shot as well. I mean the whole clutch system was shot, i am talking clutch, fly wheel, and pressure plate. I lucked out, since the mechanic is my best friend's father, he only charged me $450 for labor, but I had to pay $1,000 for the parts. Good luck though!
  1. Help: Help !!!! My transmission is stuck in gear
    By 2002ssslp in forum Manual Transmission
    Last Post: 02-25-2013, 06:32 AM
  2. Transmission stuck in gear
    By Spexes in forum Manual Transmission
    Last Post: 10-17-2007, 04:53 AM
  3. weird.. stuck in fourth gear???
    By DW2000TA in forum Manual Transmission
    Last Post: 06-14-2007, 04:08 PM
  4. Replies: 24
    Last Post: 06-05-2007, 03:01 PM
  5. Replies: 9
    Last Post: 06-01-2007, 05:18 PM
