Results 1 to 2 of 2
    Vicksburg. Ms.
    pewter
    99 Trans Am
    Need Help On Ignition Switch On 98 Gmc
    I Placed Ignition Switch Cylynder An Now The Theft System Has It Shut Down So Fuel Pump Will Not Work ,cranks But Goes Right Back Dead
    I wonder if the vats system on that is comparable to the f-bodies. If so you can bypass it with a resistor. Look at the stickies at the top of the forum.
  1. Is this the Ignition Switch?
    By mike171562 in forum General Help
    Last Post: 08-16-2012, 02:16 PM
  2. Help: ignition switch
    By txoutlaw69 in forum Firebird / WS6
    Last Post: 08-15-2012, 02:51 AM
  3. Question: New ignition switch
    By 98maro in forum General Help
    Last Post: 02-18-2011, 06:03 PM
  4. Ignition Switch
    By silverado777 in forum GM Trucks
    Last Post: 10-30-2007, 08:36 PM
  5. ignition switch
    By dczfirst in forum General Help
    Last Post: 09-12-2006, 06:31 PM
