Thread: ignition switch
    Missouri
    1992 firebird
    ignition switch
    how hard it it change the ignition switch on 1992 firebird?
    Thank you
    Senior Member Redphoenix1998's Avatar
    Apr 2002
    San Jose
    1998 Pontiac Trans Am
    from what I heard a PITA cause it's behin the dash
    Missouri
    1992 firebird
    thanks for the reply but would u mind to tell me what PITA means??
    Thank you
    Missouri
    1992 firebird
    oh ok never mind I know what it means now lol
    VA
    WHITE
    2000 CAMARO
    take the (4 )7mm screws from under the dash panel and drop it. Unbolt the (2) 10mm bolts from the steering column bracket lower it slowly. The ignition switch is about 12 inches down from the top of the steering wheel. Place the shifter in neutral, apply the parking brake remove (2) phillip screws, and unhook the wiring connectors. Last slide the ignition switch up and out
    45minutes- 1 hour max
  1. Is this the Ignition Switch?
    By mike171562 in forum General Help
    Last Post: 08-16-2012, 02:16 PM
  2. Help: ignition switch
    By txoutlaw69 in forum Firebird / WS6
    Last Post: 08-15-2012, 02:51 AM
  3. Question: New ignition switch
    By 98maro in forum General Help
    Last Post: 02-18-2011, 06:03 PM
  4. Need Help On Ignition Switch On 98 Gmc
    By Street Fighter in forum General Help
    Last Post: 11-02-2007, 08:36 AM
  5. Ignition Switch
    By silverado777 in forum GM Trucks
    Last Post: 10-30-2007, 08:36 PM
