Thread: temp
10-29-2007, 05:52 PM #1Junior Member
- Oct 2007
- usa
des- 1998,trans am
temp
is it normal for my temp gauge to be at 210? it been staying around 180ish
10-29-2007, 07:45 PM #2
Mine normaly sits around there considering the fans dont kick on until.
fan #1 226*
fan #2 234*
10-30-2007, 05:36 PM #3www.eautocad.com
- Oct 2007
- FL
Silver- 1998 Camaro Z28
why would you have your fan temp set so high? I thought its good to keep the engine cool to increase performance
10-30-2007, 05:49 PM #4Senior Member
- Jul 2005
- Jacksonville, FL
I've got my fan temps set pretty low and a 160 - reads just under 210 cause of the crappy gauge. You '98 guys have a working gauge, so if I noticed a significant increase in temp I'd look for something being wrong.
10-30-2007, 07:01 PM #5www.eautocad.com
- Oct 2007
- FL
my temp gauge is crap, it doesn't work 99% of the time. But when it does I run at 180 so it appears. What can I do to fix it?
10-31-2007, 08:28 AM #6Senior Member
- Jul 2005
- Jacksonville, FL
If the gauge isn't working I'd look at the ECT connector/wiring. If the wiring looks good try replacing the sensor, they're not expensive.
10-31-2007, 08:29 AM #7
10-31-2007, 01:20 PM #8www.eautocad.com
- Oct 2007
- FL
gauges in the pillar is what I need to invest in... i need at temp, water temp, and oil temp.
10-31-2007, 05:30 PM #9
Check out Thunderracing.com
J
Thinking of putting Oil Temp & Trans Temp gauges
By ernie22golf in forum General HelpReplies: 1Last Post: 12-27-2014, 10:39 AM -
What's your temp?
By SiggyZ in forum Almost Anything GoesReplies: 32Last Post: 07-01-2012, 09:30 AM -
Question: Fan Temp
By MrKid in forum General HelpReplies: 9Last Post: 06-14-2010, 06:09 AM -
Hi Temp
By radome in forum Showcar and DetailingReplies: 9Last Post: 11-16-2008, 04:29 PM -
Temp goes up, when ac goes on
By SR71 in forum General HelpReplies: 5Last Post: 08-26-2007, 09:55 PM
