Results 1 to 10 of 10
Thread: Fan Temp
06-12-2010, 08:50 AM #1
Fan Temp
I just installed a 160 degree thermostat on my new motor. What should I set each fan at. There is an on/off temp for each one.
06-12-2010, 11:20 AM #2Senior Member
- Apr 2008
- Madison, WI
I've heard those 160 T-stats don't actually open until the low 170s. So you wanna set the low speed fan to come on a little higher than the opening temp of the t-stat. So some where in the 175 to 185 degree range. the fan off temp temp should be about 5 degrees colder then the on temp.
So maybe try this:
low speed ON at 185...OFF at 180
High speed ON at 205....OFF at 200
06-12-2010, 11:21 AM #3
How about 160 & 180 ? You can experiment with them a little.
06-12-2010, 11:23 AM #4
Then again, I don't have a t-stat...
06-12-2010, 11:25 AM #5
Good thing I asked! I was going to set low for on at 165 off at 155. Maybe I should stick to setting my house thermostat. lol
Thanks a lot, Cutlass!
06-12-2010, 11:26 AM #6
06-13-2010, 04:27 PM #7Member
- Nov 2006
- clarinda
Black- 1998 firebird formula ws6
i Had my tuned by frost to 160 thermo but how do you change the fan temps? are you suppose too?
06-13-2010, 05:56 PM #8
i agree with cutlass post.. rkvette
06-14-2010, 05:39 AM #9
06-14-2010, 06:09 AM #10Member
- Nov 2006
- clarinda
Thanks
Thinking of putting Oil Temp & Trans Temp gauges
By ernie22golf in forum General HelpReplies: 1Last Post: 12-27-2014, 10:39 AM -
What's your temp?
By SiggyZ in forum Almost Anything GoesReplies: 32Last Post: 07-01-2012, 09:30 AM -
Hi Temp
By radome in forum Showcar and DetailingReplies: 9Last Post: 11-16-2008, 04:29 PM -
temp
By venom98 in forum General HelpReplies: 8Last Post: 10-31-2007, 05:30 PM -
Temp goes up, when ac goes on
By SR71 in forum General HelpReplies: 5Last Post: 08-26-2007, 09:55 PM
