Results 1 to 11 of 11
Thread: SES: Codes 1133 and 1153
11-17-2005, 03:20 PM #1c1823aGuest
Here's what happened. 6 or so months ago I installed O2 sims on the rears because of a "catalyst ineffiency" code. Dealership and GM would not allow free replacement of converters because I had a K&N air filter that I put in about a year ago. They say that the oil used in the filter will contaminate the catalyst. After a lot of arguing on the phone with GM I gave up on them. That's why I installed the sims. Everything was fine until I gutted the cats the other day. Now I'm getting the 1133 and 1153 codes. "Fuel/air metering error". Can anyone help with solving this problem???
thanks,
Kyle
11-17-2005, 06:11 PM #2WS6BIRDGuest
I would have complained to gm that if the oil in the air filter damaged the converter the maf should have gone out first. It sounds like a easy way out for them. I used to work for a chevy dealership and would see k&n air filters all the time. and not once did it ever void a warranty. I have replaced a converter on WS6 with a filter,lid and other things and no problems replacing converter. the dealership does not have to call gm for warranty repairs. the should have fixed it free of charge. just my 2 cents.
11-18-2005, 03:07 AM #3c1823aGuest
I agree. When I called GM, they read out a list of items that will void their warranty. An aftermarket, oiled air filter, was one of the items on their list. They could have made it up while I was on the phone with them. Who knows. What I do know is that I had a bad cat and GM would not authorize a replacement under warranty.
11-19-2005, 07:59 AM #4
Go to a different dealer and put a paper filter in
11-19-2005, 11:45 AM #5Senior Member
- Jul 2005
- Jacksonville, FL
1133 and 1153 are banks 1 and 2, sensor 1 (precat) 02 insufficient switching codes. Not sure if gutting the cats caused them, but sounds like it could have. Here's a couple possibilities out of the manual:
"When 1133 & 1153 are set at the same time, it is a good indication that a fuel contamination condition is present."
"An exhaust leak 6-12 inches away from the H02S..."
"Certain RTV silicone gasket materials give off vapors..."
"...advise customer to try different gas company."
Don't know if this helps - just a couple ideas, of course they're assuming stock cats. I'd resolve the issue soon though since it's both front 02's.
11-19-2005, 02:11 PM #6c1823aGuest
Thanks for the reply. I've been reading on another site that this has happened to a few people after gutting cats or installing long tube headers. Some were able to fix it with Vette, rear 02's. It's said they run at a higher wattage and will allow the sensor to heat up properly. May have to try it.
11-23-2005, 07:17 AM #7NH Camaro Z28Guest
Actually, we've been having similar issues under a thread created by DiPeRRi 99 under SES problem. I have a code scanner and posted some freeze frame information. It seems as though we're all having the same issue.
11-23-2005, 08:19 AM #8c1823aGuest
Update: Swapped my rear O2's with the front O2's and has been working for 3 days now. SES light went out by itself and hasn't turned back on "yet". I guess it's possible that both front O2's went out at the same time after gutting the cats, but I don't know about that. I'll keep you posted if anything changes.
Hey NH Camaro, have any of you tried the Vette "rear" O2's in the pre cat position??? I was told the Vette O2's run at a slighlty higher wattage and the leads are much longer. Good for Long tubes with no extension lead. Don't know if any of this is true, just what I read on another board.
later,
Kyle
11-23-2005, 08:38 AM #9NH Camaro Z28Guest
I've never tried the swap. I did find out from one of my technicians that the ground for the O2 sensors are through the threads themselves; therefore, if the threads aren't clean in the bung or the sensors, the light may come on. Hard saying not knowing.
11-28-2005, 08:08 AM #10c1823aGuest
Update: So far, NO SES light. May need to give it some more time.
03-13-2008, 01:03 PM #11Junior Member
- Mar 2008
- chesterfield sc
black- 2001 trans am ws6
im having the same problem i gutted my cats and about 2 days later my ses light came on the code that came up is p0161 02 sensor heater circuit malfunction bank 2 sensor 2 do u think the vette rear o2's will make the ses light go off or any other suggestions
Help: p-codes
By Train in forum General HelpReplies: 25Last Post: 07-05-2010, 07:30 PM -
codes 1153and 1133 same time Please Help!!!!!
By VENOMOUS in forum Computer & TuningReplies: 4Last Post: 11-14-2008, 10:49 AM -
code 1133?
By BLKHAWK in forum General HelpReplies: 15Last Post: 01-24-2007, 07:34 PM -
SES Light Code# 1133
By stevegrizzle in forum General HelpReplies: 6Last Post: 10-26-2006, 11:12 PM -
Engine Code 1133
By FlewbyurGT in forum Computer & TuningReplies: 3Last Post: 08-20-2005, 02:16 PM
