    General Mota's! stevegrizzle's Avatar
    Around Tampa , FL
    mid blue
    99 m6 z28
    SES Light Code# 1133
    Need to know what it is and what caused it/how to fix it. I know its 02 sensor related.
    Senior Member
    Jacksonville, FL
    Slow response, bank 1 sensor 1 - drivers side precat sensor. www.gearchatter.com/viewtopic8902.php
    Around Tampa , FL
    mid blue
    99 m6 z28
    thanks
    Around Tampa , FL
    mid blue
    99 m6 z28
    so i put in 110 leaded at the track, would this lie under fuel contamination?
    I had this come on once before and i reset it, and it didnt come on until i put leaded gas in it again.
    LS1 land
    you put leaded gas in your LS1???????
    Around Tampa , FL
    mid blue
    99 m6 z28
    yes. i mixed 2/3 93 oct with 1/3 110 oct leaded, there was a noticable difference.
    Alcohol Injected PaganEgyptian's Avatar
    Knoxville,Tn
    1999 Pontiac Firebird
    You may have lead fouled your O2 sensors. Thsi is easy to do especially if they are older and have mileage on them. NGK makes a Lead resistant O2 sensor you might want to look into.
    After some time of driving with 93, the lead will eventually blow out of the pores of the sensor, it took mine 250 miles once for it to turn off the SES light. Then I replaced them with new sensors. Be aware of using Bosch O2's, they are junk. I recommend NGK or Standard. FYI, running more than 20% 110 octane (2gal to 10gal) is overkill, unless you are highly modified. -Tim
  1. p0410 code and no ses light?
    By Ortiz11b in forum General Help
    Last Post: 09-16-2011, 06:14 PM
  2. ses light came on, come in to help with code
    By krese in forum General Help
    Last Post: 04-28-2008, 11:47 AM
  3. SES light, A.I.R. code?
    By ArcticZ06 in forum General Help
    Last Post: 09-29-2007, 08:46 PM
  4. code 1133?
    By BLKHAWK in forum General Help
    Last Post: 01-24-2007, 07:34 PM
  5. Engine Code 1133
    By FlewbyurGT in forum Computer & Tuning
    Last Post: 08-20-2005, 02:16 PM
