Results 1 to 18 of 18
Thread: Climate Control
    Connecticut
    2000 Camaro SS M6
    Climate Control
    Ok so here's an interesting question. We all know that camaros (isn't it weird that 'camaro' gets underlined as incorrect by the spell checker?) don't come with climate control. Well maybe they do, but at least I've never seen it. So my question is: can you give your camaro climate control with an a/c control panel swap? Or is that also controlled by other redundant systems? I only ask because I have a '98 Blazer with climate control and it'd be nice if I could make the switch.
    Berkeley, CA
    2000 Camaro SS #3574 A4
    they have climate control, it's called the air conditioner and heater. which control the climate of the car. I dunno what you're trying to ask. haha
    WI
    Blog Entries
    1
    09 EclipseGT 75 Chevy 4x4
    2001 Trans-Am 13 F-XT
    I was thinking the same thing when I was reading his post. I'm guessing he means dual for pass/driver and that would be a whole bunch of modding.
    Berkeley, CA
    you can always use my method, turn the knob to AC, turn the other knob to the left or right, and then select your fan speed. that's how I do it at least. haha, I'm just bustin your balls man.
    Member Joe00SS's Avatar
    CT
    White Liquid Silver
    2000 Camaro SS/ 02 YZF-R1
    I always found it weird that Camaro comes up as an error on spell check...my car has climate control, I roll up the windows when its cold and let them down when its warm and bonus take off the T's...LOL
    Member Mr. Hyde's Avatar
    Seattle
    Jetstream Blue Metallic
    2008 Z06 Corvette
    Gentlemen, it's his 3rd post, let's welcome him a little better than this! He's probably referring to today's newest cars with all the lastest gizmos...did I say gizmos? I'm gettin' so old..that yes refer to individual settings, as well as setting a actual temp. on the screen [dial] and it adjust the car's temp. to your liking. Just like you're in your living room I guess.
    CT
    White Liquid Silver
    ^^^Party pooper...haha...you still didn't answer his question even though you were nicer...
    Connecticut
    2000 Camaro SS M6
    Ok ok let me clear up the confusion here. What we have in our cars right now is your standard heat and a/c(so nice for some of you to clear that up for me.......that was joke). The climate control that I'm referring to is the AUTOMATED feature that some GM vehicles have as an option. It looks similar to the control panel we have, except the fan and vent location knobs have an 'auto' setting. The temperature control also has degree increments on it. So for example, you set the fan and vent to 'auto', and then you select the temperature knob to a temperature that you always want the car to maintain. So say you set it to 70 degrees....the climate control will then either run the heat or a/c depending on what the ambient temperature of the car is at that time.
    My 98 Blazer has it. It's an option that probably comes with the LT package. Google a picture image of it if you're still confused.
    Connecticut
    2000 Camaro SS M6
    Here's a photo of the panel screen. This isn't exactly like the one I have, but you get the point with those 'auto' setting I'm referring to.
    Connecticut
    2000 Camaro SS M6
    Here's the exact picture from a blazer/jimmy. I'd like to think that the one from the camaro and the blazer are of the same dimensions. So would swapping them work?
    CT
    White Liquid Silver
    Good find if it does...try it and let us know.
    Connecticut
    2000 Camaro SS M6
    That's the thing though. I'd hate to rip apart the dash on both vehicles just to find that it doesn't work. If no one knows, I'll probably eventually try it, but I'll have to wait until the summer to make sure both heat and a/c kick in.
    Berkeley, CA
    my mom had a 07 Caddy CTS with a crazy climate control. it's so confusing to use. I like the AC in my car better actually. way more simple and easy to use. but I guess that one pic you put up is fairly simple looking. I dunno if it would be worth the work tho.
    I have a need for speed! jigger1166's Avatar
    Standish,Maine
    Artic White
    00 SS Vert.
    Ok, I'm a GM Service Technician, and I can answer your question.
    Swapping the control panel will not work.
    The control panel tells the Body Control Module (BCM) what to do. So, unless you have the programmed BCM, it won't work. You'd also need a temp. sensor to tell the BCM what the temp. in the car is.
    JIGGER RACIN'
    2000 Camaro SS, vert., auto., LS6 intake manifold, SLP lid, K&N filter, SLP LoudMouth II, C5 Z06 replica 17x9.5 rims
    1/4 mile time = 13.310 sec. @ 105.22 mph, 2.051 60'
    http://www.cardomain.com/ride/2939958
    http://i158.photobucket.com/albums/t...amarolaeft.jpg
    Seattle
    2008 Z06 Corvette
    Okay jigger1166...here's my question while we're on the subject. Can I install my Barcalounger into my 2001 SS Camaro and make all the electric seat functions work?
    CT
    White Liquid Silver
    everyone knows the barcalounger works with the stock harness...no programing needed...duh...haha
    SS-EIAN SSNAKEATER23's Avatar
    CHICAGO
    SILVER
    1999 CAMARO SS
    climate control.......who needs a/c of heat for that fact. it's all about the car no ammenities just HORSEPOWER
    Whisper Lid/SLP HarmonicBalancer/MAFTranslator/DiabloTuner A-Pillar Gauges (Aem Uego A/F,Trans Temp, D-Pic)Magnaflow CB w/CME Tips/ Eibach Pro Kit/ Brembo Cross Drilled/Slotted Rotors/ H.I.D.Kit
    Standish,Maine
    Artic White
    00 SS Vert.
    Quote Originally Posted by 01LSS6Camaro View Post
    Well you'd have to install a power inverter. LOL
  1. Ac climate control ???
    By jayroca in forum Firebird / WS6
    Last Post: 10-13-2016, 04:55 PM
  2. Climate Control Auto Mode failure?
    By Jon02EB in forum Corvette
    Last Post: 06-13-2007, 03:31 PM
  3. Digital Climate Control
    By craig9132 in forum Corvette
    Last Post: 04-26-2007, 04:50 AM
