Thread: Ac climate control ???
09-25-2016, 08:30 PM #1Junior Member
- Jan 2016
- maryland
Ok guys i got a ?.. i recently have replaced my graphite dash for a way nicer ebony one being as im goin for a full ebony interior look.... but when i finished the dash install i noticed i dont have the climate controls working right now... everything from what im seeing is clipped/plugged in for the climate control is there a paticular plug or harness that controls the hvac? Pics wouod be greatly appreciated Thanks !!!
Sent from my SM-G928T using Tapatalk
09-25-2016, 10:04 PM #2
I'm no expert on this kinda thing, but I've noticed that each connecter seems to be unique. If the two ends fit together, then they belong together. I could be wrong on that, though. Also, are you sure you did not introduce a short somewhere?
When I was installing my MGW shifter, I had to remove the center console. I dropped one of my bits in the area where the parking break circuit connects to the lights. When I got everything back together, I noticed that I did not have any dash lights. I spent two days trying to track down what I'd left unplugged (even ripped the center console apart a couple times).
Finally, I tracked down the fuse for the dash lights and it was blown. My initial thought was that I should try to locate the short, since that's what probably blew the fuse. But I gave up after a while and just installed a new fuse. Once installed, the problem was solved: the short I introduced was a momentary one and just needed a new fuse. So dozens of hours and headaches later, a $3 fuse and 10 seconds of labor fixed the issue. Go figure.Lid, Throttle Body, LS6 Intake, Heads, Cam, Magnaflow, LS7 Clutch, SFCs, STB, Panhard Bar, Strano Springs, Hollow Sway Bars, Poly/Roto LCAs, Konis, MGW Shifter
09-26-2016, 06:06 AM #3Junior Member
- Jan 2016
- maryland
09-26-2016, 08:29 PM #4
Is anything else not working?
10-12-2016, 11:47 AM #5Junior Member
- Jan 2016
- maryland
10-13-2016, 04:55 PM #6
^^ This (probably).
Climate Control
By Finally in forum Camaro / SSReplies: 17Last Post: 10-27-2007, 12:55 PM -
Climate Control Auto Mode failure?
By Jon02EB in forum CorvetteReplies: 3Last Post: 06-13-2007, 03:31 PM -
Digital Climate Control
By craig9132 in forum CorvetteReplies: 2Last Post: 04-26-2007, 04:50 AM
