    down with the lot lizards blackhawk01's Avatar
    Pensacola
    2001 Camaro SS A4
    alternator..now battery?
    Alright..so Im driving and the LS1 does its thing to conserve battery power by shutting down everything...then it took the car..great...so I confirmed it was the alternator..i replaced that..took it for a drive to "break it in". My needle is in the yellow..but its in between the two yellow things...its not the alternator..and im pretty sure I dont have a short. I think maybe I just killed the battery by trying to run the car with just the battery..can someone confirm this for me?
    Senior Member
    Jacksonville, FL
    I'd bring the battery to your local parts chain store for a free load test.
    Slow SS
    P-Cola
    2002 Chevy Camaro
    completly draining a batter with a bad alt will kill it. More likly is that your alt went bad a little more slowly and the combo of that and te sudden failure killed the battery
    Pensacola
    2001 Camaro SS A4
    Alright..so I went ahed and took off the alternator and ended up raplacing a bad one with a bad one...so then I went and got a NEW one rather than a refurb..
    Now I have another problem
    The system is charging with about 13v...i guess thats normal. Now..my car doesnt feel like it has the "gidde up and go" like it used to before I started having these problems. Throttle response time is sloppy and it takes a little more time to get up to speed than it needs to..i checked the spark plug wires to see if they were all correct and they are. What else could be the power problem?
    Slow SS
    P-Cola
    2002 Chevy Camaro
    you have a working alt now that is putting more tension on the belt?
    Senior Member
    Jacksonville, FL
    Earlier when posting I was thinking about my friends experience with reman parts store alternators - he went threw a couple before buying a new GM unit which finally fixed his charging issues - mentioned the battery test first because it's free. On a cold start voltage should be greater than 13V on the gauge, a digital volt meter across the battery terminals will give a better reading. Maybe it seems different because the battery was disconnected resetting the PCM? I'd give it some time/miles.
    Pensacola
    2001 Camaro SS A4
    yeah..i dont know why but it seemd like a firing problem at first..then i let it sit..and restarted it and drove it around the block again...now its got the "umph" that it feels like it used to...at least I know i have a new ALT that shouldnt go out on me. The car has 71k on it..I want to start modding before its too late
    Slow SS
    P-Cola
    2002 Chevy Camaro
    Anytime you buy a reman part at the parts store, make the employee test it first. I always do this because making sure that you hand the customer a working part before he leaves is way better than having the same guy come back pissed as hell because they built his reman wrong.
    I use remans for the most part, if you test them first to make sure they are good you will be fine. They still come with a full warrenty for the most part, and you can usually get the for a lot cheaper then a new unit.
    /works at a parts store part time
  1. Battery / Alternator Problem
    By cpw006 in forum General Help
    Last Post: 04-05-2010, 09:23 PM
  2. Alternator bad? or battery? or ground?
    By 96z28 in forum General Help
    Last Post: 08-21-2008, 02:01 AM
  3. Need help with my Explorer XLT '00 battery or alternator?
    By Hurley711 in forum Domestics and Foreigns
    Last Post: 06-10-2008, 06:33 PM
  4. battery/alternator gauge...
    By bolden3 in forum General Help
    Last Post: 08-31-2007, 08:21 PM
  5. alternator vs. battery charger
    By ss~zoso~ss in forum General Help
    Last Post: 03-08-2006, 05:25 PM
